Heat pump tries to start but won't. air is constantly running.
No cold air
  • Farley Redfield
    Farley Redfield May 11, 2010
    Pretty general description. Do you want me to guess as to whats wrong or what is running and what is not, and if the breakers have been turned off aNd back on? If you tell us something less general and more descriptive we might be able to offer some advise. How old is it? How long have you been working with it 2 or 3 summers... What was the last thing that went bad on it? Any unusual smells? Any hot spots on the equipment? You know the regular stuff.
  • 614 Answers
I need to know more but it sounds like a capacitor. Check the capacitor. If it is oily or swollen top it is bad. Micro farads are marked on the side. It will 35 - 5 30-5 . Rusty
Posted on Jun 05, 2009
Should a heat pump run all the time?
It really depends on the climate and the design. In Michigan where the winters are cold and the humidity high the air cooled heat pumps run constantly, but here in Arizona they cycle on and off like a regular air conditioner. That's the best answer I can give. Hope this helps and good luck.
Oct 05, 2014 | Carrier 52CQ-312-4 Comfort Series Heat...
Heat pump condenser fan starts then stops in cold weather
does it heat ok? this is normal in cold temp as fam is not needed in cold temps. try it on warmer day and it will probably run. dont think you have a problem
Jan 30, 2014 | Heating & Cooling
2000 hyundai sonata won't start on the first try
Could possibly be a weak fuel pump.
Aug 30, 2017 | Cars & Trucks
Ive got a 98 cadt diville thats over heating i put in new radiator thrmastat and water pump but its still over heating
you might have a coolant air lock! most cadillac have a bleeder screw on top of the thermostat housing, loosing screw only when engine cold pure coolant in wait untill coolant start running out the screw hole rapidly then tighten screw, start engine let it run your fan should start working too, GOOD LUCK
Jul 06, 2011 | 1998 Cadillac DeVille
Somethimes t gives a tikkend sound by a half hour and then it stops and you onely hear a constant quit noise. greeting Mary
Are you trying to heat with your air conditioner?-- here are a few points to keep in mind:
Remember, for an air conditioner to PUT OUT HEAT-- (as HEAT PUMP) -- there has to be some HEAT outdoors, to make the process work...
So-- ask yourself-- How cold is it outside?
How cold was it outside, the last time that my AC worked good as a heat pump?
Possibly the coil outside is all frosted up?--
Shutting it off, and letting the outside coil defrost might help-- but-- the basic law of physics still stands: To get heat inside-- there has to be some heat outside! (Likely your unit won't give you much heat inside, when it is below 50 -- or for sure-- below 40 degrees outside!)
Give us a few temperature readings- inside and out, and then gives us clues as to what is running, and what is not-- maybe we can trouble shoot deeper. Is the compressor running?-- does it sound like it is actually working-- or just running-- sort of like 'running but not really WORKING'?
Let us know--
Mack B
Jan 18, 2011 | Heating & Cooling
Heat not rising above 62
It sounds like you have a 'heat pump'?-- and you are trying to heat in these cold snaps-- when the outside temperature is down near freezing?
If so-- Heat pumps do not work well that cold!-- so if your system was marginal at heating, when the outside air is 40 or 50 degrees F-- you quickly run out of 'heat' in the cold outside air, to move the refrigerant in the heat pump with any heat wrung out of the COLD-- to bring heat into your house!
Make sense?
Please tell us more-- like how your heat pump worked last year, etc.
Mack B
Jan 08, 2011 | Heating & Cooling
Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Feb 15, 2010 | Amana PTH123B25AJ Heat Pump Air...
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
Air conditioning problem
sounds like not enough freon or orfas valve is clogged. but most likely it is low on freon
May 05, 2009 | 2000 Oldsmobile Bravada
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
