F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
