Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Tighten door at hinge and fix latch to hold door shut.
Frigidaire Infinity Dryer door seems loose and will not stay shut. But, there's no way to tighten the hinge. The door can be moved slightly up and down to the point you have to raise it up to push the part that is supposed to latch it shut ... but it won't hold. Is there a way to fix this?
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: dryer door
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Now the gas company fies many types of appliances A.
And Frigidaire only fixes Frigidaire Appliances!
I think the gas company wastes our money !!!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: Thumping drum noise
ngfam1,
You are reminded, this is a SELF HELP web site. You are supposed to encourage people with you knowledge of how to repair appliances. Not to discourage them and tell them to call a repairman. The whole point of this forum is to AVOID a service call and NOT to promote your repair service. Give you a good rating for what? Stop begging for ratings and start actually helping!
Posted on Sep 06, 2008
  • 77 Answers
SOURCE: dryer door/casing is loose on hinge side of door
you can go to repairclinic.com and enter your model number. It will list all the parts. Find your hing and screws and your set.
Posted on Apr 13, 2009
SOURCE: The door on our Frigidaire dryer Model #AEQ7000ES1
I took the door all apart and found that there was a bolt that had wiggled loose from the hinge. I tightened it up, & it works just fine now.
Posted on Oct 04, 2009
My dryer door is loose and won't shut right.
You take a Phillips screwdriver to the hinges that hold it to the body of the dryer and turn the screwdriver clockwise until you can't turn it anymore. Holding the door up in the level position it should be in while doing will allow it to tighten properly.
Aug 14, 2014 | Kenmore Dryers
How do I fix the door on my Kenmore Elite HE5 dryer?
Sounds like the screws in the hinges might be loose (or some may have fallen out). Just tighten or replace the screws if that is the case. I guess the hinges might just be worn out (not likely).
Aug 14, 2014 | Dryers
How do you fix a dryer door on a frigidaire dryer
If it isn't latching you can take the latch from the other side and swap it. You'll need to tighten and shim the screws.
Clothes Dryer No Heat Heater Coil Replacement Frigidaire Affinity
Jul 24, 2014 | Frigidaire Dryers
Door on Frigidaire front load washer loose
have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
I have a 1997 ford thunderbird lx and the other day when i went to close the door when i got out it,it wuldnt shut i slammed it a couple times n it still wouldnt shut i really need help because i cant...
Here's something that might help you. Look at the door theres a little hook that grabs the striker on car, hold the door handle "open" and move the hook to the open position try to close the door. That should solve your problem. Hope that helps you.
Aug 05, 2011 | Ford Thunderbird Cars & Trucks
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Door won't stay closed. Door latch seems loose or intermittently will open enough to stop the dryer.
Dryer doors either have a combined switch, with a mechanical lock, or these two things are separate.
Whichever type you have, your description of the latch being loose is telling.
Part of the latch has either snapped off internally, and if so, it would be the part that was under the most pressure, due to having a spring or sprund element behind it, which should 'snap' the door shut.
If it has not broken, the two (possibly 4) mount screws that mount the latch to the door fascia have come loose
and this is why the mechanism is now unreliable.
These screws are only accessible from the interior, on the reverse side of the latch, next to the drum.
Whilst very easy to tighten, only a qualified electrician or service technician should access high voltage equipment..
Apr 07, 2010 | Kenmore Elite HE4 Electric Dryer
The door on our Frigidaire dryer Model #AEQ7000ES1 is not closing right. There seems to be a problem with the hinge on the door. Can you tell me how to fix it?
Oct 02, 2009 | Frigidaire Dryers
Passenger door dropped on my Daewoo how do i fix
Hi David,
It's either loose hinge(s) or a loose lock.
The lock is easier. Make sure the mechanism within the door is secure. The screws tight. That there is no movement of the latch assembly.
Next the hinges:
With the door fully open, position yourself so you can observe the hinges while lifting the door. It will be easier with a helper.
You are looking for movement at the mounting points of either hinge. Check mounting bolts and tighten where necessary.
Comment me back with the results.
Best regards,
Mike
Aug 22, 2009 | 1999 Daewoo Lanos
Driver Door Adjustment
Remember that there is a little play in the hinges, even new ones, enough that just a slight degree of play at the hinge axis will result in several fractions of an inch movement at the latching end of the door. The key here (assuming the lower hinge is still mounted at factory height with respect to latch) is to adjust the angle of the hinge's axis such that the latching mechanism is 1/2 inch higher than the stiker plate BEFORE tightening down the hinge's mounting bolts, then when you remove your support holding up the latch end of the door it should sag back down approx 1/2 inch and line up perfectly with the latch plate. I used to do this on an old '79 Monte Carlo I used to have and even being the smallest of the Monte's, it still had fairly long, heavy doors for back then even and could get the doors to shut/latch perfectly. I own a VUE now-a-days and its door's are featherweights by comparison so they should be fairly easy to adjust and you shouldn't have to tighten the @#$% out of the mounting bolts during the adjustment, just make sure you tighten them good when the alignment turns out correct upon final inspection.
If your adjustment sags again after shutting the door a few times, then you didn't tighten down the hinge mounting bolts enough and will have to go through the adjust procedure again making sure to tighten things up better the 2nd time around.
May 26, 2009 | 2004 Saturn VUE
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
219 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
