Question about Palm Treo 700p Smartphone
Blue green red white squares on frozen screen
First my phone out of the blue started to cycle in to a hot sync mode the when I would cancel it would cycle back to try to hot sync so I tried a soft reset no go so I tried a hard reset now I just have a frozen screen with red blue green and white squares..???? Didn't drop it expose it to water or anything one thing I did notice right before this when I tried to make an outgoing call the screen showed all the usual buttons call hold etc...but not speaker option...I never had this happen either...very peculiar second button from the left on the screen just gone not there.. then it started the hot sync thing etc..HELP!!!
I went to the hotsynch infinity loop and then it crashed to the squares. i came here last night and found out that it was wet. it wasn't wet i thought. later i felt around in my pocket and i had a tiny piece of wet carrot from dinner in my shirt pocket and that's what made it wet. i bleu it out with the air can thingee. then i used cuetips and alcohol and cleaned all the contacts and bleu them dry. thanks for your help.
Posted on Nov 27, 2009
The exact same thing just happened to me too! Tried soft and hard reset. Nothing.
Posted on Jun 16, 2009
I'm noticed white spots on the screen and from the past two days its getting worse. kindly suggest me and give me step to step cleaning process if i can do it myself.
check if the white spots are well defined square pixels on the screen. If they are then you may have pixel failure.
  • After turning on the projector, press "+" and "-" buttons on the control panel simultaneously and release the buttons when screen goes blank.
  • Press "+" and "-" buttons again to exit the diagnostic mode.
  • While in Self-diagnostic mode, the screen will run a seven-color-cycle test as following: "Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow." Ensure that the colors of the test pattern are correct.
  • If you believe it's dirt then disconnect from the power and undo the screws underneath the unit. lift the cover over the front of the machine and carefully remove the pcb to get at the optics. don't touch and glass bits with your bare fingers. clean the optics bits as necessary with a camera dust blower bellows. best of luck.
    Mar 10, 2011 | Dell 3300MP Multimedia Projector
    It doesn't show red color. i tried to do factory reset. but still problem.
    1.After turning on the projector, press "+" and "-" buttons on the control panel
    simultaneously for 3 seconds and release the buttons when screen goes blank.
    2 Press "+" and "-" buttons again to exit the diagnostic mode.
    3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
    following:
    Contact Dell if the colors are not displayed correctly.
    Mar 01, 2011 | Dell 2400MP DLP Projector
    Trying to wire the pump motor. Blue, red, black, white and green. Green is grounded to the frame, but I don't know what the other wires do. Please help.
    The black and white wires supply power to the motor so that it rotates clockwise when the machine is in it's wash cycle. The blue and red wires are opposite to the black and white. This makes the motor spin counter clockwise. The machine will be in it's drain mode mode when the blue and red wires are live.
    Regards
    Mar 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
    My new phone has frozen with a screen of a red bar, green bar, blue bar and white bar. PLease help
    Replace it or pay lots of $ to fix. unless its still under warranty, than they can fix or replace it.
    Nov 20, 2009 | HTC Snap S522 Cell Phone
    Frozen screen with 4 band colors
    Your phone is stuck in bootloader mode, it seems that you may need to reinstall your phone OS on your phone.
    Go to the HTC site and download your phone's OS files/installer:
    http://www.htc.com/us/SupportDownload.aspx?p_id=67&cat=2&dl_id=68
    Follow the installer's instructions after you've downloaded the needed file.
    Jul 19, 2009 | HTC Tilt 8900 Smartphone
    When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
    when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
    Jul 18, 2009 | Palm Treo 650 Handheld
    How do i sync supertooth light to a new mobile phone
    Turn the blueant off by holding the green button until it powers down. Put your phone in discover mode (refer to your phone's manual) then power the blueant back up but hold down the green button until the light starts flashing red and blue. Now you should be able to see it on the phone. I just discovered my Samsung I910 wouldn't pair unless I used the windows on screen keyboard instead of the Samsung on screen keyboard.
    Jun 11, 2009 | Blueant Supertooth Light Bluetooth Speaker...
    Error 0.14
    Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
    Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
    Nov 18, 2008 | Palm Treo 700p Smartphone
    Phone frozen: The screen just shows boxes of red, green, blue and white.
    Just had the same problem. When you take the battery out, leave it out for 4-5 minutes. Then when you put it in and reset while holding the on/off red button, it should start. Mind did. Good luck.
    Stacy
    Sep 07, 2008 | Palm Treo 700p Smartphone
    Palm Treo 700p Smartphone Logo
    527 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    Raj Patel
    Andrew Taylor
    Andrew Taylor
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
