You can buy USB 3 cables online. like the
5ft USB 3.0 Superspeed Black Cable Cord for Seagate Backup Plus 4TB 3TB 1TB 500G on Amazone for $8.00
USB 3 0 Cable eBay
Perhaps other firms are cheaper?
Perhaps your local electronic store has these cables in stock?
SOURCE: My laptop doesn't recognize Lacie Rikiki Go 1TB.
Hello roblau99:
First lets try this. Shutdown your laptop and reboot. Once your up and running, plug in your portable hard drive. You might try a different USB port. If windows doesn't let you know its there then you need to look for it by going into your administration tools menu. Of course this depends on what version of windows your are running, if it is windows.
Maybe you can answer this? Have you been disconnecting that hard drive without telling windows you are going to disconnect it first? If the answer is yes you may have corrupted that drive which is why windows is not recognizing it.
Good Luck and just let me know if you need more help.
Sincerely, Peter N.
SOURCE: LaCie Rikiki USB 3.0 connection broken
Can you open the case and remove the HDD? I looked at the specs on the device and I didn't see what interface the drive is, I would assume it's a SATA, I don't know for sure. Can you ID it? You can get a USB 2.0 to IDE/SATA Adapter: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554 You can remove the HDD, here are some examples : http://www.ultraproducts.com/applications/category/category_slc.asp?CatId=2781&name=2.5
>>>>I found the specs on the HDD inside, it is a SATA, (samsung hm500ji) : http://www.newegg.com/Product/Product.aspx?Item=N82E16822152168 , You can use the adapter to remove data and erase HDD and return for replacement under warranty.
