Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Black & Decker GH600 Trimmer spool will not feed automatically
I have had my trimmer for several years now and this is the first time that it will not automatically feed the line. I use the pre-wound spools recommended for this model. Can it be fixed or do I need to buy a new trimmer?
5 Suggested Answers
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: changing spool on weed trimmer
useless
Posted on May 10, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
tomgswan
  • 30 Answers
SOURCE: Black and Decker electric trimmer (grass hog)
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Posted on Jul 02, 2011
Grasshog gh600
grasshog gh600 I'm not a pro; by know means but could be that it could be warp in the wrong direction,frist or may be a spring or something was left out.
Sep 03, 2012 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black and Decker electric trimmer (grass hog) model GH600...eats thru line, one spool lasts about 3 minutes
Jul 02, 2011 | Black & Decker Black and Decker & Grass...
How do I change the cord in my electric Black & Decker weed trimmer? No. 8209 4.3 amps Where do I put the cord? In which direction do I wind it?
Look here (you will need Adobe Reader )
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/244137-01,GH600.pdf
Look under Operating Instructions....Spool and Line Replacement. This model is probably same as yours in that regard. Diagrams and instructions are included.
Sep 14, 2010 | Black & Decker 14" Grass Hog Xp...
String will not feed for BD grasshop Gh600 type 2
Have a problem with your B&D GH600 trimmer? Replace part LEVER, Item #29, Part #598435-00 for about $3.00 (B&D or Dewalt). Just pull old level straight out with pliers (ends expand to hold it in place) and push replacement in. No other parts.
Jul 31, 2010 | Black & Decker String Trimmer Cordless 12"...
String won't advance automatically. Thank you so much for any assistance! It's a Black & Decker ST 7000 edger/trimmer.
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Apr 06, 2010 | Black & Decker St7000 13'' Automatic Feed...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
791 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
