Question about Canon Speedlite 430EX TTL Flash
Speedlight 430ex not working
Speedlight 430EX During a recent firing test, upon pushing the test button I heard a pop sound from inside the flash unit and then a burning smell followed, no flash. When I checked the batteries they were so hot I could not hold them in my hand without burning myself. What could be going on here? New batteries put in it and it does not flash ready. The back lighting comes on and the text is shown.
SOURCE: canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Posted on Apr 15, 2009
  • 6 Answers
SOURCE: Canon 430EX Flash
Canon Flash manuals available at
www.orphancameras.com
Posted on Dec 12, 2007
SOURCE: Canon Speedlite 580EX
Buy the 550EX, it's cheaper
Master /or Slave = 550
Slave = other
Alexander
Posted on Dec 22, 2007
  • 155 Answers
SOURCE: Slave Flash
I'm guessing you're talking about a wireless connection...
Unfortunately, the 430EX can only act as a slave. You'll need one of the following to act as a master control unit: 550EX, 580EX, 508EX II or the ST-E2 transmitter :-(
Matt
Posted on Feb 29, 2008
SOURCE: I have a broken 430ex
The problem was solved and I have a bad bulb. The information was gotten by searching google and then following the photo expert blog.
Posted on Aug 24, 2008
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Speedlite 430EXII Flash not working. Batteries OK Everything functioning except that it's not firing. Took 3 pics yesterday and then it stopped working. Regards Alan Paramor
Does it fire when you push the test button (red light)? If so make sure the contacts on the lens and on your camera are clean. My speedlites sometimes don't fire after heavy use and I clean the contacts with a soft cloth and some methylated spirits or isopropyl alcohol. Hope this works for you.
Jan 21, 2011 | Canon Speedlite 430EX TTL Flash
Canon 430EX II flash... batteries A-OK. But flash doesn't fire... tried pilot... doesn't work
Hello
Thank you for using FixYa for your problem
Sounds like the flash tube has gone.
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Canon speedlight 430EX II won't fire
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
Jan 24, 2009 | Canon Speedlite 430EX TTL Flash
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon Speedlite 430EX TTL Flash Logo
289 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
