Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
  • 6,784 Answers
Check the following to address this issue--
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 03, 2009
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Does not drain water out at end of cycle, I have tried cleaning out all the screens,have opened the impeller cover and checked that the impeller is clean and free. When I put together, it runs for 2 or 3...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
Diswasher won't drain
Hi
Thanks
Rylee
Dec 08, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Diswasher is holding water in base after washing, not completely draining what is wrong?
Hi
Thanks
Rylee
Dec 08, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
There is water at the bottom of the diswasher. How can I drain this or what should I look for to fix it
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water not draining from diswasher
Hi
Thanks
Rylee
Nov 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Diswasher does not drain after rinse.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Maytag Dishwashers
Maytag DWC7602 drainage problem from tub bottom
OK. Try these steps.
-If hooked up to a food waste disposer, be sure the "knock out" is removed from the disposal inlet.
-Be sure the drain hose is ELEVATED at least 32" so water cannot siphon back in the tub.
-Check for a food obstruction in the drain or disposer.
-Check drain hose for a kink.
-Check your home's circuit breaker or fuse box.
-Check that the cycle is completed.
Hope this helps you!
Apr 22, 2009 | Maytag 24 in. DWC7602 Free-standing...
Dishwasher does not drain
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
good luck
Dec 25, 2008 | Maytag MDB9600A Jetclean II Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
430 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
