Question about Logitech R-20 Computer Speakers
To much bass
Ya id like to know how to trun down the bass the subwoofer is over powering the sound of the 2 speaker
SOURCE: subwoofer control
You just may not be used to the full sound this unit creates. Most amplifiers/speakers cannot replicate the frequencies this unit provides. Simply stated, you just may not be used to hearing lower frequencies. However, here are a couple of things that you can try.... 1. Check you music source. If using an MP3 or a music program, make sure that your equilizer settings are flat (or on another setting with less bass.) 2. Subwoofer placement is critical. You may have this unit placed in the corner of a room or under a desk. These placements can actually increase a subwoofer's response and make the sound more "boomy." You may want to try moving the sub to a different location (ie: to the middle of the wall and away from furniture.) This may help reduce the overpowering bass you claim to experience. 3. This subwoofer has a ported speaker - meaning that there is a large whole on the left side of the subwoofer cabinet. This allows the bass created by the woofer to exit the casing easily to create a more bassy sound. The drawback to this design is you lose a bit of the solid "thump" you would get from a non-ported design. Try sticking something into this hole (towel, nerf football, etc) to block the sound coming out of the port. Just make sure whatever you use does not fall into the subwoofer! I hope one (or a combination) of these help. I personally have these speakers... for what you pay, you get pretty good quality/sound.
Posted on Oct 04, 2007
SOURCE: Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Posted on Jan 01, 2008
SOURCE: Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Posted on Jan 22, 2008
  • 5 Answers
SOURCE: Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
Posted on Jul 23, 2009
SOURCE: Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Posted on Jan 30, 2010
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
I have 2 velodyne fsr 12 subs. both were taken out by PG&E power surges. One make a white noise that cuts in and out, but will still play bass when fed a signal, the other makes a loud static sound...
http://www.retrevo.com/support/Velodyne-FSR-12-Subwoofers-manual/id/866ag600/t/2/
Not that it would help.
Is the white noise present in the absence of an input connection, free-floating?
The amps in both of them sound like they
Mar 24, 2011 | Velodyne FSR-12 Speaker
I have 2 15 in 02 L7s an 2 2000w mono blocks the box they came in is to big for my trunk so i had it custumized to fit so its a lot smaller now its 16in high 21 inchs deep an 40 inches long and is angled...
When porting a box, you have to have the air resistance just right. If you are just gunna cut a random hole, id say you are better off keeping it sealed. And proven fact, bass comes out the back of the speaker so face it away from ya and toward the back of the car. Then you wont hear any Speaker Slap either
Feb 03, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I get a red light on the back panel labeled power. No green light. I don't think the PV 600 is working but when I run the channel check through my Pioneer THX receiver I hear sound. Any thoughts?
The PV600 and PV400 have auto-on circuitry that turns the subwoofer on when a signal is presented, and turns off if no signal is detected for 15 minutes.
http://www.retrevo.com/support/Boston-Acoustics-PV600-Subwoofers-manual/id/522dj484/t/2/
Not knowing which Pioneer receiver you have I have dropped in the steps for No Sound from Subwoofer:
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
Jan 12, 2011 | Boston Acoustics PV600 Main / Stereo...
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
I have a proton satria 2007 model with a fully intergarted head u
First off, change the front speakers with a decent pair of aftermarket. Buy a powered subwoofer. One that has the amp built in. Connect it to the rear speakers. Bazooka tubes are great, compact, great bass.Adjust your radio so that the front speakers do not recieve alot of bass,you want it about half way. That way you are using all the power to push high notes, Bass takes a lot of power to push, reducing the volume. Turn the subwoofer to the maximum setting, and then adjust the system to your liking. It will take some time, but it is worth it in the end. Tip: set it while listening to your favorite station. Stations broadcast at different sound levels. Some pump up the bass, some don't.
Apr 15, 2010 | Car Audio & Video
I need to know how big of an amp i need?
it really depends on ur choice but if it were me id get the biggest mono block amp i could to run the sub. and id run a 2 to 4 channel amp to power the rest.that way u get ur bass on it own supply and the voices on there own supply.if u want more detailed help let me know bertman285@hotmail.com
Sep 25, 2009 | Power Acoustik 12 1200w Subwoofer Car...
Jun 03, 2009 | Logitech R-20 Computer Speakers
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
Logitech R-20 Computer Speakers Logo
171 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
