Question about Intel Motherboard
Dont remember connection
E241819 motherboard layout i cant remember where the power sw cable connects to on the motherboard.
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
I don't see pwr-sw connector on my asus m2n-mx se plus motherboard ; i need to connect some device to it ! what i have to do ? thanks,
On the asus motherboard you mentioned the power sw connectors are here as illustrated belowavatar23454_1.jpg
as for the layout for which jumper set you need
Apr 18, 2011 | ASUS M2N-MX Motherboard
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Unable to connect HDD LED, Power LED, RESET SW and power SW jumpers to motherboard in correct position. Unable to find a manual for layout. Any help will be greatly appreciated.
If you look closely on the motherboard, and not necessarily near the jacks or pins, you will find a wiring table that corresponds to the pin configurations.
Dec 21, 2010 | EliteGroup GeForce 6100SM-M Motherboard
Help needed to connect power cables to Abit AV-8 mother board
Bottom right you will see a set of pins  - 2 rows on a black base, color coded: these are the system pins. Next to them you will find printed on the board the description of the connections to them - follow it.
Jun 22, 2010 | Abit AV8-3rd Eye Motherboard
I cleaned my pc, and disconected the wires that are right downside corner. I cant remember how to put them back rightly. Any help? hdd led power led + power led - power switch (sw) reset switch (sw)
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.3_3_2012_12_10_44_pm.jpg3_3_2012_12_10_56_pm.jpg
Jun 15, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
How to connect power sw and led and reset sw and hd led
You'll need to go to the Elitegroup website and download the .pdf file showing a diagram of the motherboard wiring layout and pin connections and then connect the wires from the case to the proper locations.
Oct 07, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Don't know which pins to connect the power sw cable to.
Here is the Layout and installation of your board. Hope this helps.
http://www.bcmcom.com/tech/SL620/SL620-manual.PDF
Jan 29, 2009 | NEC PGA370 SIS620 ATX Motherboard...
Intel Motherboard Logo
622 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
