Question about Kitchen Ranges
Our fan forced wall oven St George Model no. W.D.L.V. 81 F.O. is only heating up to about half the heat it always did, then the roasting light comes on even though the roasting function is not supposed to be operating. Could this be a faulty main element?
    Brigadier General:
  • 8,619 Answers
Hi
You need to check the screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
If the temperature is too low then the possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
Hi I have an old 1970's St.george imperial wall oven and I can't turn the roast light off which makes the oven heat up to under half the heat it normally does. How do I turn the roast light off?
since I have no model or serial, I assume this is an electric oven based on the description provided. this is usually an indication that the heating element has gone bad. possibly having a short to ground which completes a partial circuit in turn giving you heat and a light. I would look in this direction first.
Jan 04, 2018 | Imperial Ovens
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
I have St. George Imperial Fan Forced Oven with Griller (Wall Oven) SGW FO need measurements and specs also model number ?? Can someone please help me have been looking on net for ages...Getting...
you should find the model number between the bottom of the griller door & the liner .. silly place really to get at... as you cannot remove the grill door as you can the oven door.
we have just rebuilt one from two we acquired ... best oven ever .... there will be a few different models as these were produced & cosmetically changed over a 20 yrs period. Ours now looks like a brand new oven as they are REAL baked enamel ... you can clean with caustic based product without any harm.
I am searching for a manual if anyone has one mine is 67/wdl.v.81.fo I presume the 81 in the number denotes 1981 manufacture.
Don't be fooled if you find the oven does not heat at some stage & everything else works ... this is usually after a cleaning & the auto on & off timer has been activated ...just a matter of setting back to manual mode.
Hope this helps although you have probably solved by now having posted in April 11.
Anyone have a manual for this model would be appreciated .
Apr 16, 2011 | Ovens
DEO-6 top oven doesn't heat when fan oven is used
check wiring to cavity air pressure switch terminals eg the two wires should be connected to common(c) and Normally open (NO)
May 16, 2010 | Ovens
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Hi, we have a St George wall oven that is making a loud rattling noise that starts when the oven is heated and then comtinues after the oven is turned off. Any ideas on what might be the problem?
there is a casing fan which is out of sight and that is what is making the noise. take oven out, remove top and fan will be revealed. may have to be replaced or possibly try a squirt of wd40
Oct 02, 2008 | Kitchen Ranges
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Kitchen Ranges Logo
157 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
