Question about Brother DCP-7020 All-In-One Laser Printer
I have a Brother DCP7020. It is making a grinding sound when it tries to print and I can't get the front to open. The right side seems ok but the left is hung up.
    President:
  • Brother Master
  • 1,447 Answers
Your copier drum unit is lock you open all cover & trouble shoot this problem
Posted on Jun 03, 2009
  • Sazeed Computer
    Sazeed Computer Nov 22, 2009
    its problem machanical please repear or service it by expert
Loud grinding noise front end while driving. Hub bearing? Started a few weeks ago but not so extreme and usual only when turning. Now it is a loud metal grinding sound almost constant and seems to get...
Probably so. When making a left hand turn, if the noise gets loader, it is the right side bearing. IE... putting more wieght on that side of the car.
Jun 01, 2013 | 2003 Chevrolet Avalanche
I have a Brother HL 1440 that had the paper jam in the front and back, crumbling up in the process. I cleared both locations with no success. The ready and alarm continues to flash and the printer still...
Check the following steps for fixing Brother Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 15, 2010 | Brother HL 1440 Laser Printer
I got grinding it the front wheel bering,,but only the left
ok you have a bad right front wheel bearing by what you are describing
Sep 04, 2009 | 1997 Ford Aspire
How do you change the drum on the brother dcp7020
Open the front door, pull the toner and drum assembly straight out towards you, press the blue lever on the left to remove the toner cartridge and install it in the new drum assembly and re-install in machine. While the front door is open press the clear button, display will ask "new drum?" answer yes, all done...
Jun 19, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Noise from front end more so when you are turning
You also could have received a bad axle. Sometimes the rebuilds don't hold good tolerance and can make the same noise you are trying to get rid of. Is it full-time 4wd? Maybe the driveshaft ujoint also.
May 19, 2009 | 1998 Jeep Grand Cherokee
Green ready light on, but will not print
When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
Aug 09, 2008 | Brother HL-2040 Laser Printer
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother DCP-7020 All-In-One Laser Printer Logo
245 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
