Question about JVC AV-36260 TV
JVC AV-36260 TV Problem TV won't turn on
I turned the set on, then it turned off, as if a fuse blew, When I try to turn it back on nothing happens. Help!!!!!!!! a red light is blinking on the tv and i will unplug it and then plug it back in and the red light will stay on for 4 second and then goes out the power went out for a second and i need help of this problem
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The blinking red light is like an error message that indicates to a service tech what's going on with the set. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need a power supply module. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
Tv comes on then black square pops on screen
Hello
Closed caption option is "ON". Just turn it 'OFF' If the remote control of your tV has a "CC" button. press it once. If it has't that button, you have to enter its Menu option, surf through, and come to closed caption function window, and select the closed caption OFF.
Feb 28, 2012 | JVC AV-36260 TV
Jvc tv av36230 was working fine one day tried to turn it on the next and nothing. its like its un pluged but it is. is there a fuse or something inside?
Yes, TV sets have a fuse inside (in a holder on the circuit board near the power cord connections) and it may be bad, but that's unlikely to be the trouble. Fuses seldom just go bad on their own, and if you find it's blown there's usually some other part that causes it. A dead TV is not always easy to fix, and you generally need the services of an experienced technician with the tools and information to track down the problem.
Have you tried unplugging the TV from the wall, letting it sit for a minute, then plugging it back in? This will reset the computer inside (if it's getting power), and sometimes that's all it takes. If not, you can take the back off the TV (MAKE SURE IT'S UNPLUGGED!) and check the fuse, but that's about all. As I said, if it's blown it will probably go again if you replace it, and if the fuse is good but the set won't come on it will need professional help.
Good luck, and thanks for using Fixya!
Jun 06, 2011 | JVC AV-36230 36" TV
Big black rectangle JVC tv
turn off your closed caption
Mar 20, 2009 | JVC AV-36260 TV
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
Dec 30, 2008 | JVC AV-36260 TV
JVC projection screen with blowen fuse
You have to check the reason , why the fuse blew. It is something else that made the first fuse blow. The fuse has nothing to do with picture after the TV starts up.
Dec 02, 2008 | JVC AV-36260 TV
JVC AV-36260 Is there a fuse in this TV or is it a circuit breaker, if it is where is the fuse / circuit breaker located. I am am electrical engineer, but can not find any specs on the inside of the unit
All modern TV's have fuse devices,some glass,some chemical.
However,a blown fuse comes from a short circuit,which I'm sure
you are well aware.Let's talk diagnosis--What is your set doing
or not doing?? Is it dead?==No "on"?? If there is no bad fuse,the
most common solution is a bad capacitor in the power circuitry
number sequence==900's. Ex..C953    value== 1000mf/35v.
Other caps in power supply may be weak.
2) Check Horiz output transistor---shorted? Look for blown B+
fuse + weak or open C523 1mf/160v in horiz drive circuit.Replace
horiz out with high-quality OEM transistor only.I use JVC only
on 32" size & bigger ( you have 36" ).
  Let me know by rating this solution...thanks...T.
Oct 22, 2007 | JVC AV-36260 TV
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
HELP!!!!!!!!!!!!!!!!!!!!!!
goto menu and find CC close caption and it should be set on TEXT. Turn off.
Oct 09, 2007 | JVC AV-36260 TV
JVC AV-36260 TV Logo
810 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
