Question about Polaroid FLM-3232 Television
Volume turned off
My grandfather somehow turned off the sound on his TV. Of course I tried both the mute button and checked audio menu as well as trying the global unlock mentioned in the owner's manual. We also tried both the vcr & dvd players and there was still no sound. He say's all he did was push a button and it went off. I also double checked the layout of the buttons in the manual but could'nt figure it out.
Please help
        Wes
  • 1 more comment
  • Anonymous Dec 07, 2007
    I have the same problem...no sound..any ideas on how to fix this would be appreciated!
    I also have no sound. I have tried all of the menu adjustments...unlocking the volume via the remote..still nothing. Does anyone know if there is a fuse that could be affected? Of course the warranty is up as of last month!
    Thanks!
  • reds657 Dec 28, 2007
    I have no volume and a beautiful picture. Do you have any advice for me.
    The tv's alittle over 1year old.
    panda
    Genius:
  • 1,694 Answers
Try hard reset = Leave ac cord unplugged overnight....
worth a try.............T.
Posted on Dec 07, 2007
  • 4,102 Answers
Try manually turning the vollume up on the telly itself if this dont solve the problem try pressing the av button on the controll in case that has changed as sometimes this will stop the sound make sure the controll is working but other than that their should be no reason why you get no sound unless its something inside the telly that has gone wrong if this doesnt solve your problem take it to repair shop and they should tell you for free what is wrong with it hope this is some help
Posted on Oct 30, 2007
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
No volume today on my tv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 02, 2016 | Televison & Video
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
    Mar 08, 2014 | Vizio Televison & Video
    Have lost sound on my dish TV and mute button is not on
    Is there sound using the set top box? Try a different remote if possible. Last but not least, Call Tech Support.
    Oct 14, 2013 | Televison & Video
    Muted my sharp le 810 and now i can't retrieve the sound
    If you push the volume button on set does it show on screen?
    My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
    Does not sound (pardon the pun) like a circuit repair but like an error.
    Check all audio settings or options first in the set and then the box.
    Mar 21, 2012 | Sharp Televison & Video
    No sound
    Check the speaker icon in the taskbar at the bottom, if there is an X then it is muted. Right click to unmute.
    Also as it is a laptop there may be a mute button on the keys using the function button and a typical mute icon on a key or even a seperate button altogether.
    Mar 18, 2009 | Microsoft Windows XP Home Edition
    No Audio Out to Stereo Reciever
    First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
    Sep 11, 2007 | Hitachi 51F510 51" Rear Projection...
    Polaroid FLM-3232 Television Logo
    103 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
