Question about Amana ABB2227DE Bottom Freezer Refrigerator
Can I get a set of black gaskets for my 15 year old Amana ?
It is a bottom freezer and it's white and I want to paint it black, but I cannot find black gaskets.
  • 10,865 Answers
Go to an auto supply store, one that the professional autobody guys use. They will have black paint that works on gaskets.
Posted on Jun 03, 2009
I have a Hotpoint HSS25GFPH white side by side refrigerator. We're buying a new house with black appliances. I don't want to buy a new refrigerator so I'm contemplating painting the whit
Paint? unless you have a spray booth, and are good at such things, I would avoid that...
I would go with a vinyl or similar adhesive sticker. There are companies that do whole fridge front stickers with artwork/nature pictures etc. Google "refrigerator stickers" and you might find one that will do, just plain black.
Apr 24, 2012 | Hotpoint HSS25GFP Side by Side...
How do I replace door Gasket?
White plastic strip just to the refrig side of the center gasket needs to be removed first, then gasket pulled back enough to reveal gasket retainer. Use a flat bade screwdriver to pop out the white clips at the top and bottom allowing strip to be removed. Now gasket can be easily pulled out of groove. Be careful when re-installing clips to get springs in correctly.
Feb 19, 2011 | LG LFX25960 Titanium Bottom Freezer French...
Did a kitchen make-over and want to change our white fridge doors to black-can we spray paint them?
Yes, you can buy black appliance paint in a spray can. Do a good prep job first.
On site that sells it...
http://www.globalindustrial.com/p/maintenance/paint/aerosol/krylon-appliance-epoxy-paint-black?utm_source=google_pr&utm_medium=cpc&utm_campaign=Aerosol-Paint-google_pr&infoParam.campaignId=T9F
Feb 28, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Rust on outside of freezer door -- is there an epoxy or white coating to cover over the rust?
You can clean off using a green scrubbing bad and some brasso all at wall mart then buy a can of spraypanit and spray it with food grade paint by Krylon paints also at wal mart. The paint will seal it and keep it from comming off.
Nov 12, 2009 | Amana ABB1927DE Bottom Freezer...
I have a bottom freezer amana model BG20TW. It
salt has turn the paint and get some rustolum primer and appliance paint that they sell for your particular item and repaint it you can go to the sears web site to get the paint in aresol type can
Aug 19, 2009 | Amana ABB1927DE Bottom Freezer...
I have an Amana bottom freezer frig. The freezer is starting to show frost inside and build up. Also I noticed some white snow looking stuff under on the front corner. Its not cold like ice but hard white...
the ref. is pulling in air from the gasket.check gasket by using a dollar bill.shut the freezer door with dollar bill between gasket and freezer.if you can pull the bill out wit ease then you must replace gasket.if frost is on back panel then you have a defrost problem.but it sounds like a gasket.
Mar 05, 2009 | Amana ABB1927DE Bottom Freezer...
Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Feb 11, 2008 | Freezers
Alarm on
hector...this sounds like icing up! First thing is to defrost this unit. The ice is preventing air flow over the coils. Shut down and get warm air to the coils. Then, let everything dry. If you leave off and open for 2 days, this will do it. Causes: humid conditions, 'window shopping' or bad gaskets. If the gasket surfaces are dirty, clean them. Test any questionable areas by taking a 2-3 wide strip of paper and close the door on it. If the paper pulls easily, the gasket is bad.
Now, clean out the condenser coils. They are located in the back or under the unit and are always painted black. Then, have a look at the compressor. It is that big black thing in the bottom with pipes sticking out of it. Look at the larger pipe. When you start the unit, it should frost and then either dry off or condense water after about 5 minutes. If it stays frosty or is not cold, you need gas. If the unit passes all these tests, you may have a defrost timer issue. Let me know.
Nov 19, 2007 | Electrolux 9.46 cu. ft. / 268 liter...
Amana ABB2227DE Bottom Freezer Refrigerator Logo
76 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
