Question about Mtd Heavy Machinery
MTD chipper blade adjustment
I would like to know how to adjust the chipper blades ( the clearance) on a 6.5 hp MTD model 24B-464B062 chipper/shedder. I am not sure what the clearance should be between the blades and the anvel..I do not have a manual
SOURCE: I don't have a manual for the tomahawk chipper and
You will need to turn the flails (also called cylinder hammers).  Each flail has  4 sharp corner cutouts, only one of which is in use.  When you turn them you get to use a fresh corner, the dull one is still there but no longer contacts the stuff you are chipping.  You will need to remove the chute to access the flywheel, and by rotating the flywheel access the steel bars (cylinder pins) that hold the flails and spacers.  I lay the chipper down, with a 5 gallon bucket protecting the engine, gas tank, to access the bottom, so that you can, using a punch, drive out the 3/16X3/4 roll pin which can be found in one of the long spacers.  You will note each bar has 4 flails, with two long spacers and two short spacers and the roll pin goes through one of the long spacers.  You buy the roll pin punch at a hardware store.   There are four sets of bars with spacers and flails, so four roll pins.  You will want four fresh roll pins also, because the old ones are compressed and shouldn't be used again.  When you have punched out the roll pin you can then drive the bar from the end (where the chute was) but be sure to line the other end of the bar up with the hole on the other sidewall of the chipping compartment.   When you are trying to punch out the roll pin it helps to stabilize the fly wheel--I use a couple of vise grips in a way that the fly wheel is stable.  When you are pounding out the bar (called a cylinder pin) you will need a slightly lesser diameter long (6-8") bolt as a driver.  You can pound on it and it will follow the cylinder pin as it gets pushed out the other side.   When the spacers and flails fall out onto the floor, then you can turn the flails to use a fresh cutting corner and put the spacers and flails back on.  I find it helpful to file the rough edges of the inside ends of the spacers so they slide easily on the cylinder pins.  Get a round file for this purpose.  Also, keep some WD 40 on hand because these things tend to be stuck.  I do only one cylinder pin (with its four flails and four spacers) at a time, so I correctly put it all back in the right order.   You will see that the the order alternates.)
Posted on Mar 23, 2009
SOURCE: pulley size on Troybuilt Super Tomahock Chipper Shredder
Yes I solved my problem and it was rather easy, I should have thought of it before I wrote, My son ia a Mechanic for Hertz Rentals, I asked him. Thank You for your assiatance. R. Todd
Posted on Mar 26, 2009
  • 91 Answers
SOURCE: 5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Posted on Mar 30, 2009
vincob
  • 718 Answers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Posted on Oct 09, 2009
rwvanlue
  • 486 Answers
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
Posted on Nov 08, 2009
Why does my MTD tractor screech and die when I engage the blade?
Sounds as if the valves need adjusting... You will need a feeler gauge and find out what the specs are for that engines valves clearance...
Oct 11, 2015 | Mtd Garden
I want the length of my grass taller. How do I adjust the blade to achieve this? Or is it the wheels?
Hi, are you saying that you want it taller than the highest blade setting? Meaning the highest notch on the blade height setting lever?
May 06, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Need replacement chipper blades for 5HP tomahawk chipper. Older model distributed by GardenWay. Model # 47255. Probably pre 2001 bankruptcy action. Would settle for specifications (L,W,Thkness) and type of...
This is the only source that I know of for the older chipper blades. Problem is you need to know the dimensions.
http://www.wesspur.com/chipper-knives/chipper-knives.html
There is an MTD one that is for troy-bilt but was not able to match it up with your unit due to pub issues here on my end: PN is MTD 1901782MA
I recommend you contact these folks to get it sorted out:
http://www.wesspur.com/contact-wesspur.html
Hope this got you pointed in the right direction.
Thanks for using FixYa.
Kelly
Jun 26, 2010 | Troy-Bilt ChipperShredder
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a troy bilt mulcher model 47057 serial number 470570100839. We need to buy some more blades etc where would be the place to buy the parts from
I would check with an MTD dealer. I look online and found a site for the chipper blades and they wanted $40.00 USD for each. It may be worth your time to take the other ones out and get them sharpened.
Good Day.
Oct 12, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
Describe your Troy Troy-Bilt® Briggs and Stratton Chipper Problem how to take impeller assemply off troy-bilt chipper model cs4210
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Jun 26, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
Heavy Machinery Logo
362 people viewed this question
Top Mtd Heavy Machinery Experts
rjivaro
Roland W VanLue
Roland W VanLue
obsteiner
Are you a Mtd Heavy Machinery Expert? Answer questions, earn points and help others
