Question about Goodman CLJ30AR32 Air Conditioner
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
Got home today and the air will not come back on. The out side unit is working but the indoor blower will not come on. Also the light on the control board is not and will not light up. Can someone help?
  • 116 Answers
Turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Posted on Jun 03, 2009
Can not blowing as hard as it should. Compressor kicking on but freezing up easily. Any ideas?
Check your filters and make sure that there is adequate airflow, also make sure that any drain tubes are not plugged.
Jul 03, 2015 | Heating & Cooling
Why my Midea a/c 60,000 BTU showing PC error at the indoor unit?
Make sure your indoor blower is blowing, If not you have either a control problem or a bad blower motor.
Sep 17, 2014 | Midea Heating & Cooling
York central unit condenser does not run. Red Led light on circuit board keeps blinking.
There seem to be a problem with the unit that is why it is acting that way. If the air conditioner is not working but has the power light blinking. Yet the fan is not running, then you need to troubleshoot the unit. There are some tips for troubleshooting the air conditioner to be able to detect the problem and know the best appropriate procedure to solving the problem.
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs.
Good luck.
Jul 14, 2011 | Heating & Cooling
I have a GE BTB736A100A2. Does the dinosaur have an air filter? If so, then where is it? Thanks.
Hi, if this is a package unit, both heat and air all in one, the filter normally is put in a return vent in the ceiling indoors. If you have a split system, outdoor condenser and indoor blower unit, it may be the same, in your ceiling or on a lower wall near the furnace. It may also be inside of the indoor unit either above or below the blower fan. Depending on the sq. footage, you may have up to 2 or 3 return air filters. If you have looked through out the home, and you don't see any grill, it would have to go in the indoor unit if this is a split. The filter is always located on the return side of the unit, the side that draws air back over the indoor coil. If you can find nothing, you may need to buy some filter media at a hardware store, and try and cut a piece to fit where the air flow is being drawn back into the blower compartment, not the supply air coming in, but going back out where the indoor coil is located to catch all of the dust. Just take your time and look for any register that you can feel air being sucked into, and this is where you can put a filter. If you do find the grill and old filter, it will have the size and a arrow on it and it will go in with the arrow going in the direction of flow, you can feel it. I hope this has given you some direction and help.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 31, 2011 | GE Zoneline AZ58H12DAD Air Conditioner
Air conditioner blower control
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
May 10, 2011 | 2004 Mercury Grand Marquis
Whirlpool ACQ128 Air Conditioner was working then it turned off and won't power back on
Feb 06, 2011 | Whirlpool ACQ128 Air Conditioner
Air conditioner will not turn on by remote green light keeps flasing and fan on outside box not working
Dec 15, 2010 | Carrier 36KCARMS Air Conditioner
MY frigidaire Air Conditioner model number: FAC107P1A2 has suddenly stopped blowing cool air. Check Filter light comes on but filter clean. Press Check Filter light button and blows out cool air for...
Aug 24, 2010 | Frigidaire FAC107P1A Wall/Window Air...
Blower on my 2004 Mazda 6 went out
Sounds like your blower motor or blower motor resistor went out.
Jan 26, 2009 | 2004 Mazda 6
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Goodman CLJ30AR32 Air Conditioner Logo
346 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
