Question about JBL BP300.1 PowerValve Series Car Audio Amplifier
Output transistor is out in car amp
Its a fusion 1200w amp thats hooked to two 12 kickers. i need to know how to get the transistor out. i've took it apart and am afraid i will break it if i just pull the transistor out.
  • 655 Answers
Hello nymnym999,
You did not specify which Fusion amp you have but if the insides looks like the Fusion PP-AM60020 image below, you'll have to "desolder" the transistor.
First remove the heat sink from the transistor case. You'll need a controlled heat soldering station, a desoldering vacuum tool commonly referred to as a "solder ******", and some desoldering braid. Be careful with the heat around other components.
After removing the transistor, use the desoldering braid to clean off any remaining solder from around and in the circuit board mounting holes. Position the new transistor and solder it to the board. Put a thin film of thermal compound on the heat sink and remount it to the new transistor. Use just enough of the compound to insure an air-free join between the transistor case and the heat sink. Reassemble the case and you're finished.
Hope this helps.
Posted on Jun 03, 2009
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
Nov 19, 2013 | Kicker Car Audio & Video
My kicker amp is old but worked great. i hooked it up yesterday and it was fine, then just quit. the green lights still on though. could it be fried ?
mine kind of did same thing was working fine, then intermittenly, then not at all. took it apart today and two transistors are blown. might check those. take cover off bottom, then the aluminum plates towards the outer edges of circuit board. transistors are under those plates. look for any that are burnt. Can buy new ones for like 2-3 bucks, solder em in, and you're good to go. they fry from amp getting too hot. could be from running it too long or wiring it up at too low of an impedence level, making it run much harder and hotter.
Mar 20, 2010 | RTO Kicker Impulse Audio Windshield Banner...
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Amp wont trun on
your amp its not connected as it should be, moust schenge the conections
May 16, 2007 | Kenwood KAC-9102D Car Audio Amplifier
JBL BP300.1 PowerValve Series Car Audio Amplifier Logo
1,185 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
