Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi ws 55809 convergience
I am having a problem with the convergience on my mitsubishi ws55809 tv. I cannot find the covervience chips. Does any one know where to look for them and where to find a schematic?
    Genius:
  • 1,239 Answers
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
Red convergence on my ws-55809 is off
The lense adjustment won't help. There are two convergience chips inside, each has 16 pins. If you take the big tray, with all the boards, out and turn it over, you will see that one of the chips has a pin that goes to a contact labeled, "RH." You can't miss the chips, they are stuck to a huge, finned heat sink, about 4'' x 7". Check the continuity from that pin to it's contact with an ohm meter. You may get lucky and get by with simply a re-solder or jump on that pin. Those convergience chips are like computer processors, are subject to extreme heat, depend very heavily on their heat sinks and cooling fins and could easily get hot enough to break a solder connection. Like computer processors, they should have been designed with fans as well as heat sinks. Don't kill yourself. Even unplugged, a tv has enough stored energy to be fatal.
Mar 08, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Where are the covergence controls in ws55809 tv located
All convergence adjustments on this set are done with the original remote control--you will find the CONVERGENCE in the customer menu---if set will not adjust there you have a circuit problem.
I have fixed hundreds of these sets--if it will not adjust let me know and I can tell you what is needed to fix it.
SD TECH
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I need to replace the convergence chips in my Mitsubishi WS-55809. Could someone send me the instructions to do so, as well as any other need info for this task? Thanks, Jason utilitypigeons@aol.com
There should be a diagram somewehre in the tv set itself. If not, do a diagram search on your model number on your television, and it should show where those chips are.
Nov 23, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Convergence instruction for ws55809 please mvminton@yahoo.com
I have fixed hundreds of these sets.
They use two of the STK-392-570 CHIPS.
BEST PLACE TO BUY THE PAIR OF CHIPS IS EBAY
SEE INCOMING INFORMATION.
IF YOU LIKE IT, RATE THIS SOLUTION AS I DO THIS HERE FOR FREE.
SD TECH
Nov 19, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv vertical lines
Remove back .... lightly tap modules with plastic screwdriver
handle to isolate where bad connection is.....pull module or
chassis...solder,then repeat until problem solved......T.
Dec 24, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 won't start up.
It's been my experience that this is usually cause by a blown fuse. Check all the fuses on the boards inside the TV
Oct 22, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitssubishi ws55809
Still need help ? Check fuses on power board and let me know.
..........................T.
Mar 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
