Question about Fujitsu Plasmavision PDS-4233 42 in. Television
Vertical bar about 3/4" from top to bottom of monitor
When I turn on my fujitsu plasma pds4233w the monitor displays a virtical bar from top to bottom about 3/4 of an inch thick. The vertical bar consists of whites, blue, reds, green, and a solid black bar. Even when I change the video display or rgb display the vertical bar stays in the exact same spot. And if there's a picture being displayed on the monitor, no image can be seen through the vertical bar. Pls. Or can u refer me to a repair tech closest to Stockton, California. I bought this plasma @ goodguys and they are no longer in business.
  • 643 Answers
Panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Posted on Jun 03, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
On a 58" diagonal plasma, I have an approximate 3-1/4" wide pink vertical bar in the lower left corner of the screen. It does not go all the way to the top of the plasma, it stops mid-way on the scre
There is some connection defects. If you wish to know more about these kind of fault to plasma displays, check this link. There is illustrations to compare with, which cannot be included by this window.
Feb 25, 2013 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
I need to swap motherboards from fujitsu t.v how can this be done?
If you remove the back of the tv you will see where the boards sit, you will have a power supply, Decoder/signal board plus other boards that convert the horizontal and vertical signal.
Mar 06, 2012 | Fujitsu PDS4233W Flat Panel Television
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
LG Plasma Monitor has recently developed a screen fault
change vertical ic and filter cap 1micro
Jul 02, 2009 | Televison & Video
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Black vertical line 3inches in from the left on my fujitsu PDS4233W-H plasma screen
If the line is all the way from top to bottom, it could be your upper and lower buffer boards or your plasma display unit is bad. I suggest you contact a servicer for your brand.
Apr 01, 2008 | Televison & Video
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Fault in Plasma display screen
Depending on the location, it could be the Logic Main Board, or a buffer board
Mar 06, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Fujitsu Plasmavision PDS-4233 42 in. Television Logo
544 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
