Question about Goldstar MV-1501 Microwave Oven
My Goldstar 1500 Micro wave no power
Heard a pop and power to the control panel went out. I replaced the 10amp fuse to no avail. - please advise
  • jameskarasek Jun 03, 2009
    My wife said she went to turn the light on, on the control panel and that is when she heard the pop sound
    President:
  • 1,902 Answers
HEating element popped and needs to be replaced. Also check for discoloring on the sides and back of the panel. This will also tell you what is going on. Make sure that the power cord did not break either and that it is fully attached where it is supposed to go
Posted on Jun 03, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 03, 2009
    Then check the control board. Make sure that it is not fried in any way and that there are no burn marks. But it is still recommended that you check for discoloriasation on the side of the unit internally to make sure that nothing happened in there
Product went out in storm. It beeps to reset but nothing happens.
Hi, it sounds like you have had an electrical power surge to the unit and it may have blowen some part in your unit. Only way to find out is to get it checked out by repairer.
Mar 21, 2016 | Microwave Ovens
We purchased a Maytag microwave MMV4205BAQ about 3 years ago when we remodeled our kitchen. I put a cup of water in the microwave to boil and when I touched the Start button, I heard a small POP behind...
if microwave is counting down but no heat you either have a loose connection at the magnatron tube or the thermal cut out fuse that is connected to the magnatron has blown or you have a micro switch, that has failed
Feb 23, 2011 | Whirlpool MMV4205BAQ Microwave Oven
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
The surface lights burned out so I was going to replace these. I took the lens cover off and when to unscrew the bulbs when I heard a "pop" no there isn't any power to the micro wave. What do I do now?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
You should of course replace the fuse, but always work with the oven unplugged.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Oct 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Acts as if there is no power but power at the outlet. Neither micro nor vent fan nor light work. Please advise.
Their is a fuse insite the body behind the control panel. You need to replace the fuse.
Sep 29, 2010 | Sanyo EM-S8000 Microwave Oven
Over the Counter Goldstar MV1501 1500 watt microwave tried to change the range light. As bulb was being unscrewed I heard a pop and felt a slight shock, now microwave has no power. Outlet does have...
You can download the service / repair manual here.
Most computers will open the manual automatically, but you may need the free Adobe Reader.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and reference numbers. Unfortunately it does not give you part numbers for some reason...
You can find & order parts from Encompass here or you can call them toll-free at 866-779-5835.
I would first check the fuse and oven thermostat.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions here are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once the fuse and oven thermostat are known good and the microwave functions, if the lights / fan still won't work or won't shut off, then you have a problem with the control board.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
You should check your light sockets for a short, too.
Jun 27, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
The toaster on LG LMF-9030TW combined with micro-wave is not heating. The fuse is ok and wiring also. Cannot bring it to repair shop cause I will be out of micro-wave for 2-3 weeks, until fixed. Probably...
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Microwave Ovens
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
122 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
