I have a 1999 GE 46" rear projection TV The sound is just a scratching sound. Is there a sound card I can replace? What can I do to save this TV? Modle #46GW947 Made In Mexico.
  • 1 more comment
  • kr_wallace Jun 03, 2009
    If i repla ce the main board will this fix my problem?
    I have a GE Model 46GW947 rear projection tv
    the sound is just a hissing sound
    can i replace this circuit board very easy or dose it require a tec?
  • 6,784 Answers
OK, there is no sound card. the sound input and out put is handled by the main circuit board(pc board). you will need to replace this main circuit board in order to eliminate this audio glitch.
Posted on Jun 03, 2009
  • Michael Masters
    Michael Masters Jun 03, 2009
    This is not easy and, if done incorrectly, it will damaged the entire set. i recommend a service tech for this repair.
  • 13,433 Answers
I have a service manual for the 46GW948, very close model number.
http://ekse.hopto.org/FixyaSupport/46GW948.pdf
its a pdf file so if you can't open the document you will need a pdf reader, its the free download on this page http://www.foxitsoftware.com/pdf/reader/
Looking it over there doesn't appear to be a replaceable board for it or card. Possibly its on the main board. A tech could very likely test and find the problem from the board and fix it.
I don't recommend a home repair unless you have experience and you know how to avoid getting yourself electrocuted.
  • Ekse Jun 03, 2009
    Yes it should.
Projection not functioning properly
this is a common problem in the projection tv faced by many users.that the sound goes out and comes properly when using dvd player on it.but its the problem of weak sound ic on the main board of the tv that has to be replaced its also called the audio ic. as the sound only comes because the dvd itself has its sound ic in the device so the sound comes from that ic which you get.
Mar 02, 2009 | GE 46GW947 46" Rear Projection Television
Stain on samsung dlp projection tv screen
Sorry to hear that. It is damaged/scratched sound like
Nov 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
GE Gemstar 46" model 46GW948
can you hear the starting or a noise from the back?try unplugging then put back.sound to me that you will need a tech
most probably the trippler going bad.
Jose
Aug 09, 2008 | GE 46GW 948 46" Rear Projection Television
Projection tv
Dear Sirs..
I have a GE rear projection TV and would like to know where the contrast adjustment is ?
Thank You Brian
Apr 03, 2008 | GE 46GW947 46" Rear Projection Television
46 inch rear projection tv bulb replacement model number 46gw944
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Feb 05, 2008 | GE 46GW945 46" Rear Projection Television
Focusing coil
What is the set doing or not doing?.....Why do you say the focusing coil ?............What is a focusing coil..........?
Please provide the service # off back of TV........T.
Dec 02, 2007 | GE 46GW947 46" Rear Projection Television
TV Repair
your power supply board needs replacing ..
Oct 14, 2007 | GE 46GW 948 46" Rear Projection Television
Need to warm up????
Sounds like something wrong in the tuner circuit How about performing a by-pass test? Use the A/V 1 or 2 inputs on the bottom rear of tv to hook-up signal.Use dvd or source box.When the set is cold,turn on and check.If the pix & sound are good,then the tv has a tuner problem. If you can live with two inputs,no repairs need to be done.Caution:observe funky,side-ways hook-up on A/V 2 !!!
Oct 05, 2007 | GE 46GW947 46" Rear Projection Television
Beep
There are no cards inside this set its stand up printed circut boards as this is not a computer.. the cards are not replaceable as they are fixed to componet level.. if your not a experienced tech Do not attemt to repair or tinker with this set as you can be seriously killed!@ Call a pro to assist you with this repair as there are no user replaceable parts inside this set. good Luck
Aug 10, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
