Question about Nikon Coolpix 5000 Digital Camera
4gb not compatable?
I went recently to buy a 4gb memory card for my camera. After I cut open the packet and inserted the new card, my camera just said either; No Card Present or No Memory Left. It was a brand new card! I don't get it. Anyone  have a solution or at least can shed some light on people. Same situation, a 4GB card bought @ Staples, it's a SanDisk, the camera reads "out of memory"
  • 126 Answers
Camera wont accept a 4gb card most only take 2 gb sd cards .
Posted on Jun 03, 2009
SOURCE:
Card error
Is this the card you always used, or did you recently buy a new card?
Because you can use MMC cards and SD cards. Most SD cards you now buy, even the 2 GB ones, are SDHC cards and they are not compatible with your camera.
You should try to get an SD card. They used to make SD cards up to 4GB, but as I said, now they already make 2GB SDHC, So look careful when buying a memory card.
If it was the card you always used, try to get all pictures from the card, using an external memory card reader on your computer. Then in the camera do a format, before you continue.
If it does not work, try an other card. SD that is.
Mar 01, 2014 | Aiptek PocketCam DV4500 Digital Camera
Memory issue
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Jun 23, 2012 | Kodak Cameras
Can i change my memory card from 2GB to 4GB or 8GB
Yes, the Kodak Easyshare M1033 has a SD/SDHC compatible expansion slot so you can purchase and insert memory cards up to 32GB. You can purchase them almost anywhere like Best Buy, Target, etc.
Mar 31, 2011 | Kodak EasyShare M1033 Digital Camera
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
C190-caot be read with 2 differnd SD 4GB cards. Is
Hi sir
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 15, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Ive bought a new memory card for my pentax optic e10 camera when ive inserted it it is reading memory card error what can i do
This camera takes an SD (secure digital) memory card according to amazon and google. Looks like your using a Sony Memory Stick Pro Duo which would not be compatible.
Try using an SD card.
Jun 13, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Camera doesn't acknowledge card when inserted into camera
Hi
Whats the capacity of your memory card? check for compatibility of card, since memory cards that have 4gb to 8gb are not compatible with some cameras. check as well from your cameras manufacturer if they have a firmware that will support such cards for your device/camera.
Hope this helps
May 10, 2009 | Konica Minolta DiMAGE A1 Digital Camera
4gb not compatable?
It could be as simple as a bad card. Take it back or try it on another camera to verify.
Mar 10, 2009 | Nikon Coolpix 5000 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Nikon Coolpix 5000 Digital Camera Logo
469 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
