Question about Kenmore Dryers
Dryer won't heat up to dry the clothes the heating element works
The heating element is ok, the dryer run good but it would still heat up to dry the clothes
  • Anonymous Mar 21, 2014
    I have no heat while dryer is running
  • 6,784 Answers
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jun 03, 2009
SOURCE:
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
The dryer will run, but it will not heat to dry the clothes, and the dryer will not automatically turn off. The dial will move by itself but stall at the end and keep running-help!!!
It sounds like your heating element has gone bad. The dryer has a sensor within it that detects that amount of moisture in the dryer. It will keep running until it doesnt sense any moisture. If the heating element is not working, the clothes will not dry. You can replace this element if you are somewhat handy. It it sometimes hard to find an element but you may be able to find one on-line if your local appliance store does not have one in stock. Good luck.
Jan 06, 2011 | Dryers
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My Whirlpool heats up, everything is clean. Clothes will NOT dry! Excessive moisture present when I open the dryer door after running for 120 minutes. Had this problem before and the ductwork was clog
Are you sure the fan is working . Also the heating element could be shorted to the heat element cover. Take an ohm meter and check from the heating element to the cover if you get ohms it is shorted if the meter don't move it is ok. If it is shorted you get half the heat not hot enough but still feels warm. Hope this helps good luck..
Mar 30, 2017 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Nov 20, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
305 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
