Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Loud fan on side by side Whirlpool Estate refrigerator
It is very loud. will it continue to keep the food cold? we cannot get a repair man tonight and are afraid if we go to sleep it will either quite working or catch on fire or something. HELP!
    President:
  • 1,902 Answers
It should not catch fire. Will it keep working is basically up to the fridge itself. As long as you keep the doors closed when you go to sleep everything will stay cold and frozen for over 24 hours so you will be ok with that. If you are really worried about a fire then unplug the system before you go to sleep
Posted on Jun 03, 2009
My whirlpool fridge starting make a loud noise on and off
You could have a ice block fan, take all your food out and keep it cold, then unplug the unit with doors open and let it defrosts 3-4 hours if this solves the issue you should do this process once every 2 months. If not is time for special service
Aug 19, 2016 | Whirlpool Refrigerators
I have a Whirlpool refrigerator (model # ET2AHTXLT00). It intermittently makes a loud clicking noise that comes from the left side of the refrigerator (when youre facing it). It still is cold inside both...
What you are hearing is the fresh food damper. It sounds like it stuck open or stripped. You should have a tech look at it. It could stick closed and make the fresh food section too warm. Ihope this helps.
Aug 25, 2011 | Whirlpool GC5SHEXNS Side by Side...
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then...
the noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Jul 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
All of a sudden, my refrigerator doesn't keep anything cold like it used to but the freezer still works. We have cleaned underneath but it still doesn't keep anything cold. What could be the problem?
Look for signs of frost on the back side. You probably have a defrost problem of it could be a drain problem.
Your ice box cold air originates in the freezer. A fan pushes down the cold air into the fresh food section. If their are too many items in the freezer the air can be blocked to the fresh food section. If the drain stops up sometimes a puddle forms a slab of ice between the freezer and the bottom. I ave an apartment maintenence man's guide to these ice box's for you HERE. It feature 4 differnt styles of whirlpool ice box's in your size.
May 25, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Fan keeps making loud rumbling noise
probably not tied in with each other, would change the fan and probably jump the water valve with 110 volts and see if you get water if not then change the water valve if so change the ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool ED2FHSS Side by Side...
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
107 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
