Question about EnGenius EOC-3220 (EOC3220)
How to split WIFI signal between one radio and two antenna?
I have 1 WIFI operated 2.4 Ghz with 20DBm transmit power radio currently uses Channel 1 / 2412MHz and attached with it one 18Dbi patch antenna. Now, I have planned to split the signal into two since I was operated only at limited area. I want to expand my signal to the other side in order some of my friends can conned to my Access-Point.
Hoping for such immediate solution to come up. Thank you very much.
Need Help,
Philip
  • Cheater Cheater Oct 25, 2007
    Hi Benimur,
    Thank you very much of your excellent idea but It is very conflicated to build-up your suggestions. As of now, I have planed to buy a new one to face in other area.
    Once again, thank you very much.
    Best regards,
    Philip
    Brigadier General:
  • 6,966 Answers
Hi Philip,
To answer your question, from a single TX/RX device (your WiFi unit) to a dual antenna, what you would need as a splitter is more commonly called a "phasing harness".
A phasing harness is a balanced transmission line which is used when you want to stack or use two antennas from a single radio output. In lower frequencies it is made from a pair of 75 ohms high grade coaxial cable of equal odd quarter wavelengths of the operating frequency. The joint at the middle is connected with a “tee” connector with another cable (standard 50 ohms cable) that runs down to the radio. The free ends of the 2 75 ohms coax are then connected to the two antennas. This  site shows phasing harness for multiple antennas.
For microwave region, since losses tends to be magnified, commercial grade are often used rather than home brewed. Examples are shown in this page.
Alternately and perhaps simpler is to just remove the reflector of the 8Dbi patch antenna of the EOC 3220. Normally in designs such as the 3220, the active patch antenna is soldered on one side of the PCB.  At the back is another which looks just like it but slightly bigger. This is the reflector.  The reflector has two (2) purposes:
1.    block any signal coming in from and going to the back of the active patch antenna; and
2.    reflect any back signal of the active patch antenna and re-direct it forward to effectively increase the front signal.
If you decide to remove the reflector, there will be 3 effects on the performance of your TX/RX device:
1.    the front (major) lobe (roughly the front radiation pattern; maximum distance and area covered of the front signal traveled) will be greatly reduced;
2.    that reduction would be translated to a rear coverage; and
3.    it is highly possible that you will have small side lobes as well.
This   document  would give you an idea on the lobes and radiation patterns.
Good luck.
Posted on Oct 24, 2007
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
Tip
Problems in CB Radio Receive and Modulation
Much of the time complaints about CB receive (RX) and modulation are caused by problems in the antenna system. Make sure there are no shorted or open connections in the coaxial cable or PL-259 (screw-on connectors for coaxial cable, located at the antenna and rear of CB radio) connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR (Standing Wave Ratio) of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the receive audio on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can surface in the radio itself. This will be noticed if you can transmit, but have no "modulation". Modulation can be described as the voice heard above the "carrier" (your transmitted signal). Every CBer knows about the term, modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be caused by a defective AMC (Automatic Modulation Control) stage in the receiver circuit. Also, there will be no modulation upon transmit.
One other thing could be causing this lack of receive audio. Defective wiring or switching in the microphone can result in no audio. Additionally, in many radios, a missing mike will not allow receive, because the microphone connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and fix any problems.
2. Check mike, or substitute another one.
3. Using meter, and/or another radio for listening on same channel, check power and receive.
4. You can probably fix 1, 2 and 3 yourself, or with the aid of a friend.
5. AMC problem in radio (as described above) will require professional service from a CB (Citizens Band) repair facility.
The above suggestions and advice will assist in repairing the majority of the symptoms described.
Regards, Bill
on Sep 18, 2010 | Car Audio & Video
How do I get a larger coverage signal area from the clear choice smart rg wireless modem/ router
Place it in the middle of the room. All walls, special concrete, will degrade the signal. But what also makes WiFi degrade is other modems close by. Even if they use another "channel" The best results can be achieved with 2 band modems. 2,4 GHz and 5 GHz. The 5 GZH is not yet used that much and although the reach is less, the chance other users will degrade your signal is smaller.
Jan 20, 2015 | Computers & Internet
Keeps dropping internet. the internet light on router flashes. i have to power it down and then it works for a while
Home wireless networks based on the 802.11b or 802.11g standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels.Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, Then consider buying a new wireless router as your current is deemed broken.
Dec 15, 2010 | Belkin F5D72344 Wireless G Router 54Mbps...
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 12, 2010 | Cobra 29 LTD CB Radio
Will not get good recepiton.
Hi stormnorm157,
Much of the time this is caused by problems in the antenna system. Make sure there are no shorted or open connections in the coax or PL-259 connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the audio receive on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can be in the radio itself. This will be noticed if you can transmit, but have no "Modulation". Modulation can be described as the voice heard above the "Carrier" (your transmitted signal). Every CBer knows about the term, Modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be due to a defective AMC (Automatic Modulation Control) stage in the receiver circuit. And, there will be no modulation upon transmit.
One other thing could be causing this lack of receive. Defective wiring or switching in the microphone can result in no audio. Or, in many radios, a missing mike will not allow receive, because the mike connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and rule that out or fix.
3. Using meter, and or another radio for listening on same channel, check power and receive.
4. You can probably fix 1 and 2 yourself, or with a friend.
5. AMC problem in radio (as described above) will require professional service.
Let me know how this turns out, and inform me if I can offer any more help. Thanks.
Regards, Bill
Sep 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
I want to boost up my internet connection
1. Position it better 2. Change the WiFi Channel : Wifi routers transmit their signals on a radio frequency of 2.4 GHz 3. Update firmware or drivers 4. Buy your equipment from the same company 5. Replace your antenna 6. Replace your wireless adapter 7. Add an additional Wireless Access Point (WAP) or Repeater
i know this is going to sound funny but try weird things like: Apparently aluminum foil amplifies reception and transmission. It may or may not work,
Sep 15, 2010 | D-Link Router
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
My wpn111 wireless adaptor keep dropping my router signal
There is very little you can do about this. You may not like that answer, and I am sorry for the trouble, but there are things you can try.
First, lets understand that wireless is a radio signal, much like a cordless phone. The handset has to be able to communicate with the base on a phone, and, the wifi pc's have to be able to communicate with the router. Some phones and routers (sadly) use the same frequency range, 2.4 ghz. If you have a cordless phone that operates on 2.4 ghz, or if your neighbors have one, then whenever they get a phone call, wifi goes bye bye. What can you do?
1. Upgrade your phone to a wifi friendly one, with a 2.4 ghz offset range (so that the bands are close, but not so close to cause interference) or get another frequency phone.
2. Change the frequency of the router to level 1. Usually they are AUTO or level 6. Level 1 is a low frequency, and lower frequencies usually give slower, but more reliable performance. You can choose between 1 and 11. try all frequencies to see which one gives less trouble.
3. place the router in a more centered location in the home, off the floor. Remember, this is radio. Radio antennas go into the air to receive signal, and your router is no different. A router stuck in the corner of the basement may give poor performance, while a router in the center of the home should service the home easily.
4. upgrade your wifi. Choose the wireless N router and adapters for your machines. they have better capabilities and less interference.
I hope this gives you insight into the issue. Wireless is at the mercy of its environment. Building structures, signal interference, power lines, atmospheric issues, and cordless phones can play a factor in your reception. its just like taking a portable tv thru the house and having to move the antenna around to try to get better signal. Good Luck.
Nov 05, 2009 | Computers & Internet
How to make my own wifi antenna splitter?
Philip,
If you are planning to use a single antenna and then use a "splitter" to connect two (2) WiFi units, I'm afraid that it will not work.
Antenna splitters are meant for receive only mode but since WiFi operates both on receive and transmit, then perhaps what you would need is a "duplexer".
Both of your WiFis would be operating on 2.4GHz band.  Theoretically, you would have to fix set your first WiFi device to operate on the lowest channel possible and the other on the highest channel possible. The channel separation translates to frequency difference; lowest for Channel 1 is 2.401GHz while the highest for Channel 11 is 2.473GHz.
Constructing your own would be at best a daunting task since you would need to be very familiar with electronic components and circuitry in the microwave region. Further, you have to have access to specialized equipment (microwave capable) such as a spectrum analyzer, swr meter, dummy loaded wattmeter and a frequency counter to say the least.  In most countries, you would also need certain licenses to do this.
With all of these in mind, your best bet might be to use individual external antennas for each WiFi device and positioned them as far away as possible from each other.  Moreover, pls bear in mind that anything between the transmitter and the antenna would introduce attenuation, insertion and return loss and this include even just the cable.
If you would still want to give it a try:
  1. Here is a   link  to  commercial duplexer for  amateur radio;
  2. Here’s a   link  to  a do-it-yourself page for lower amateur frequencies;
  3. This is a   link   to a component supplier page.
Good luck and kind regards.
Oct 23, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
2,038 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Bhagyanath N
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
