Question about Dell Dimension 1100 PC Desktop
Error message RUNDLL
Error loading C:\WINDOWS\Eqiluyubozidj.dat. The specified module could not be found.
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    During when do you get this error message?
  • 53 Answers
This file is not a recognized windows file it looks like a trojan or virus that is afecting how your computer boots up. You may be better off backing up all the files and documents you don't want to lose then re-format your drive and do a windows fresh install.
Posted on Jun 03, 2009
When I start up my laptop this message box comes up RUNDLL Error loading dll32 the specified module could not be found I can close the box & the laptop seems to work fine but what does it mean?
File dll32.exe is NOT a Windows core file--It is a leftover piece of code from malware.
File dll32.exe is usually located in the folder C:\Windows\System32--delete it
Jan 13, 2011 | Toshiba Satellite 2410-S203 Notebook
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
I get pop up blockers on my computer every time i turn it on.
you have virus (melware) on your machine. do you have any type of anti-virus program on the machine/ if so, please run it. if not, go to vga.com and download the antivirus software, and run it.
Apr 08, 2009 | HP DeskJet 3000 Printer
RUNDLL
It appears that a program has been removed (not uninstalled) from the computer and XP can no longer locate the removed files while references to the files still exist. So, we need to find what is referring to this file. The easiest way would be to download, install and run a registry cleaner such as CCleaner (from www.download.com), but this can also cause more problems than it solves. The other way is to use the msconfig utility to disable all of the extras that are loading and then enable them one by one and rebooting each time until the problem appears again. Then just disable the last one enabled (that caused the problem to reappear), and continue on until all other programs and processes have been reenabled.
Apr 07, 2009 | Microsoft Windows XP Professional With...
RUN DLL ERROR
IF YOU HAVE ANOTHER COMPUTER IT WOULD BE EASIER, IF NOT YOU WILL HAVE TO PRINT OUT THE INSTALLMENT DIRECTIONS FOR ELIMINATION OF THE ERROR PROMPT. IT'S TIME CONSUMING SO IF YOU ARE IN A RUSH, FORGET IT.(UNLESS YOU ARE A COMPUTER GEEK) :) YOU WON'T BE ABLE TO ACCESS WINDOWS FROM THE COMPUTER WITH THE ERROR, GO TO ANOTHER COMPUTER, PULL UP WINDOWS SUPPORT, THERE'S A SECTION THERE FOR ERRORS, IF YOU DON'T SEE IT RIGHT OFF, JUST DO SEARCH ON THE LEFT HAND SIDE BAR, "DLL" OR "ERRORS" ANY OF THESE WILL PULL UP YOUR FIX. PRINT 'EM, APPLY, AND YOU'RE UP N RUNNING!!!
Oct 24, 2008 | Microsoft Windows XP Professional
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
RUNDLL Error loading c:/PROGR-1/MYWEB-1/bar/2.bin/M3PLUGIN.DLL The specified module could not be found Can you please help me how to get rid of this at the start up please. Thax Tracie
This is a virus download " Malwarebytes " and install and run it will delete all virus files
Usually picked up downloading cracks
Get a decent antivirus suite to protect your computer
A lot of them have a free 15 to 30 day period
Aug 20, 2008 | Intel Motherboard
WINDOWS XP SP2
re install windows from windows sp2 disc.....
dont use the same disc that you already used for the previous installation
Jul 10, 2008 | Microsoft Windows XP Professional With...
Dell Dimension 1100 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
