Question about Saeco Spidem Villa
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
The unit is not grinding. How do you take the grinder apart? Saeco Spidem Villa Household Coffee Machine The grinder stopped working properly today. The grinder spins, but little to no grinding actually takes place. Took the hopper off and tried to clean out any debris,but the thing just doesn't seem to want to create any ground coffee.
    President:
  • 1,902 Answers
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Posted on Jun 03, 2009
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
Posted on May 30, 2009
Where can I get my machine rebuilt?
check with the manufacturer as to where they have authorized service centers
Aug 01, 2016 | Saeco Spidem Villa Espresso Machine
Gaggia accademia grinds too much
Make sure that your brew unit is clean and lubricated. The CPU on the machine uses the brew unit to calculate the amount of coffee it grinds. If the brew unit is dirty and hard to turn strange things will happen.
Service Center information.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Apr 27, 2014 | Coffee Makers & Espresso Machines
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
My Spidem Villa has stopped grinding beans when I press the button for an espresso. The automatic tamper tamps an empty chamber and then hot water comes out, but no coffee is ground or put into the...
Hi
Sorry but that doesn't make sence. The grind chamber has to be full inorder for the doser to activate, unless you have an oiley bean and it has hardened inside the doser.
Try removing the brew group. Then inside on the roof of the machine above where the brew unit sat, there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it should drop coffee. This should clear the opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
May 20, 2010 | Saeco Spidem Villa
It seems to be taking a long time for the water to fill the cup i just did a descaling last week
You can try to udjust the grinder one step + to more gross coffee. With this the water can run faster through the grounded coffee. However you nust count the time since the corect time is about 25 sec.
If the grinding adjustment can not make any cange then you need clean the shower which is on the coffee group since it might be full of dry coffee blocking the way of the water passing by.
Good luck
May 02, 2010 | Saeco Spidem Villa
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Repair spidem villa
A little spring felt off from the inside part when I was cleaning
Sep 23, 2009 | Saeco Spidem Villa
Broken"ON" button on Spidem Villa by Saeco
see repair shop. It is a ***** to replace,
Sep 19, 2009 | Saeco Spidem Villa
May 29, 2009 | Saeco Spidem Villa
Saeco Spidem Villa Logo
530 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
