Question about LG Electronic Window Air Conditioner
Will not run but comes on
The unit has power and everything is lit up but nothing works even just the fan by itself i can hear the unit change when changing the modes but nothing works
  • billyjoep8 Jun 03, 2009
    thanks that was fast
    President:
  • 1,902 Answers
The control board is bad. It is easy to replace and is fairly inexpensive to replace and you can do it yourself. Go to repairclinic.com or to LG.com and order the part
Posted on Jun 03, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 03, 2009
    You are welcome. IT is a easy fix like I said and the only plug you need to worry about is a long 6 wire piece that is all together as basically one and plugs into just one spot. The worst part about it is probably just having to do the job
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
My ruud achiever 90 plus furnace wont run. thermostat shows system on, seems ok but furnace itself wont run. system has power.I can hear the power come on when I depress the access panel switch and also...
See if you can locate the control board. There should be an automotive push in fuse on it. It should be a small amp fuse around 3-5 amps. Check it and change if needed. You should be able to see if it is blown or not just by looking if you don't have access to a multi-meter.
The control board is usually located in the blower compartment. Thank you.
Jul 10, 2011 | Ruud Heating & Cooling
Computer monitor don't work at all.
So basically your monitor's power supply system died.
Nothing much a non-technician could do about it.
Get it repaired, if under warranty, get a replacement before the coverage duration expires.
Jun 07, 2010 | Computers & Internet
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
My computer won't boot up or something; no power led lit.
Seems to me your Ram module connector is dirty. Clean its edge connector with a soft eraser. Or if it can, transfer it to the next ram bank. Or your memory module is already dead.
Apr 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
RUUD UPGH air/furnace just quit....no response...where to begin?
is the power light on the board lit? IF NOT THE 3 AMP OR 5 AMP FUSE COULD HAVE BLOWN ON THE BOARD
Apr 27, 2009 | Heating & Cooling
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
Power problem
Maybe you got a dry capacitor in the power supply take it to a repairmen
Mar 17, 2008 | Coby DVD-237 DVD Player
LG Electronic Window Air Conditioner Logo
188 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
