Question about GE JVM1631 Microwave Oven
Does not turn on at all it's totally dead
The microware does not turn on at all totally dead could this be a fuse ?
  • 6,784 Answers
It may be a fuse or, the power supply board. you can check the fuse by removing the cover. the (IN-LINE) fuse is located on the power supply board. check it for continuity. if the fuse is in good condition, replace the power board.
Posted on Jun 03, 2009
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
My Emerson microware just stopped in mid microwave. Completely dead. Changed plugs still nothing.
Hello there:
This is caused by a blown fuse that is inside of the microwave
You will need to first remoce the screws on the back around the edge of the back and then turn over the microwave and there should be 6 or 8 screws there remove them.
now turn the mivcrowave back over and the cover will slide away from the front of the microwave and lift off
you may have to use a flat head screw driver to get it started once the cover is off look towards the front and you will see a small circuit board that has a fuse on it simply replace the fuse with the correct one and try the mivcrowave out if all is good than replace the cover and the screws and you will be good to go from here ok
best regards richard
Nov 28, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
Aug 20, 2009 | LG LMV1630ST Microwave Oven
TOTALLY DEAD
CHECK THE FUSE ON CONTROLL BOARD, CHECK THE CONTINUITY OF THE LOW VOLTAGE TRANSFORMER.
May 02, 2009 | Microwave Ovens
Microware Kenmore mod. 721-67490790
I don´t know how but it turned on after a while and until now is working good. Maybe it turned off when I was using a lot the microware. Anyway thank you very much.
Liliana Martinez
Jun 14, 2008 | Kenmore 62622 Microwave Oven
The light inside the microware
1 take the front grill off. 2. you will see a cover with one screw around the area of the light. normally this is right in front.
May 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sick Microware
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
Feb 05, 2008 | Bosch HMT8625GB Microwave Oven
GE JVM1631 Microwave Oven Logo
286 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
