Question about Sony KP-57WS500 57" Rear Projection Television
Exploded view diagram
Where can i find and exploded view diagram of a sony rear projection tv?  a friend needs his lenses cleaned and there might be cobwebs inside of it.  i've taken many rear proj tvs apart to install screen shields, but want to make sure that i don't mess his up, since he's my chiropractor and could really mess me up if i goof.  (not that he would, but i'd rather not damage this particular tv.)
  • chipinator Oct 24, 2007
    thankyouverymuch.
    Genius:
  • 1,694 Answers
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Posted on Oct 24, 2007
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
COBWEBS DRIVING ME CRAZY INSIDE MY SONY TV HELP!
Easy way to deal with this is to unplug set and remove back cover-----with one of the Swiffer type dusters(there should be plenty of room inside this set) gently reach up and get all the webs out---also a good idea if you do this with a lens cloth or paper towel with windex clean the three large black lens you will see when you remove the cover---they usually need to be cleaned about once a year(if they are dusty the picture will be darker and not a clear)
If this has been helpful give me a vote here.
Aug 17, 2009 | Sony KP-53V80 53" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a panasonic PT 44LCX65 44" LCD rear projection TV. How do i disassemble the TV so i can clean the inside of the screen. Also i noticed on the projector lense a huge tumb print on it. not the...
I would recommend getting a service manual as the light engines are a little complicated to get out. where the manual would have an exploded diagram which would make it alot easier. If you need a link to get the manual let me know and I will post one for you.
May 03, 2008 | Televison & Video
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Cobweb?
You'll need to have the frame of the tv either opened so you can reach in there or the top mirror block assy will need to be removed to get inside to the screens. You may want to have a Sony ASC do this type of repair. Call Sony for a referral.
Dec 26, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-57WS500 57" Rear Projection Television Logo
337 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
