How to wire it and it keep blowin transformers
I have a crest audio ca18 amplifier. can u tell me which wire is for where, i have it wired black- live, white- neutral, green- ground. and the amp keep burning transformers right now am using a 5000watts transformer on it and the amp near burn it to. help plz
  • 104 Answers
I am not sure what you are trying to do, I did find two sites that have diagrams and spec sheets.
http://img3.musiciansfriend.com/dbase/pdf/spec/481640.pdf
http://www.crestaudio.com/assets/literature/manuals/CFA-CA9-AB_7719.pdf
These are Adode files.
Posted on Jun 03, 2009
Transformer power
try AE.... in Schagen, Netherlands they build new transformers and did a good and cheap job on my PT
Dec 04, 2013 | Crest Audio CC 2800 Amplifier
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
He never active and ACL Led stays on and the cooling fan go for hi speed
Hello folks,
The same thing happening with my crest cc4000. The plastic connector, connecting the wires from the transformer to the circuit board was burnt damaged and was removed. but acl light still stays on and amp not active.
Dec 19, 2012 | Crest Audio CC4000 Amplifier
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Why my crest audio ca6 has the lights clip signal
disconnect you load (speakers) power amp up. If this fault persists there might be a problemm with the amp
Apr 21, 2010 | Crest Audio CA9 Car Audio Amplifier
My amp keeps blowin fuses
try running a bigger fuse in tha power wire fuse holder
Oct 14, 2009 | Kenwood KAC-7202 Car Audio Amplifier
MY AMP KEEPS BLOWIN THE FUSE...i CHANGED THE GROUND AND HOT WIRE TO BIGGER GUAGE WIRE AND THE PROBLEM STILL THERE ..........THE AMP IS A ALPINE MRV-307
Hello creelb22,
Fuses usually blow because of a short of too much current.
Test your wiring (including the speaker wires) and make sure they are not shorting or grounding against the vehicle chassis. Also make sure that the speaker voice coils are not shorted.
Hope this helps.
Jul 25, 2009 | Alpine MRP-F300 Car Audio Amplifier
Every time I turn the amp on it shuts its self off.
disconnect all speakers and test if the problem corrected you will have a problem in your speakers(either wire or speaker itself)-try to connect the speakers one by one until you find the bad one and change it--if all above does not work send your amp to service center near you
Mar 30, 2009 | Crest Audio CPX-900 Amplifier
Fuse problems
output leads shorted by chance?
Jul 05, 2007 | Scosche Industries Scosche High...
Rockford a2 not powering up
yiur amplifaer is in protection mode you moust reset the amp
Jun 15, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
54 people viewed this question
 Grubhead
Grubhead
