Question about Vornado 723B Fan
Put the fan away for the winter - Now it won't start!
No noises made when I turn it on.
Popped the cover off the front and tried to give it a spin to assist it and still no joy.
Does anyone have any ideas?
  • 864 Answers
Spray a little WD-30 on the shaft where it enters the motor (and at the back of the motor if the shaft is visible).  Turn it on and help it spin if needed.  It should start slowly and then speed up as the bearing heats up.  The lube is probably solidified from non-use.
Posted on Jun 03, 2009
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
I have a roaring sound when i start the envoy what can it be? when I put it in neutral the noise goes away and too if i have been driving it for awile the noise goes away it only roars when I start it...
That's the fan clutch for the radiator fan. It has a thick fluid in it and in this cold weather it is ispecially thick. This makes the fan turn almost at engines speed and that makes the roaring noise. After it has been spinning a while, the fluid gets warm and gets thinner. that makes the fan turn slower than the engine. This is normal and needs no attention.
Feb 22, 2010 | 2003 GMC Envoy
Hums but wont fire
Remove the top cover, plu it back in and see if the hum goes away, if it
doesn`t look to see if the fan is stuck, if it is unplug and try to spin it
by hand, if it wont spin replace the fan motor
Feb 12, 2010 | Reddy Heating & Cooling
Spinning sound when pushing gas peddle, sitting
try it with the belts off you can start it and see if the spinning noise goes away then it's accessory's like bad alternator or power steering pump but dont run it more than a minute or two or it will start to overheat. and if it still makes spinning noise make sure it's not coming from the transmission /use a broomstick against the engine block near each piston to hear the condition of the pistons if there scored real bad it makes noticable diff noise than a diff piston will make. check the front of the engin the water pump sometimes needs to be replaced because the bearing in it drys up and fails / there sealed bearings in a water pump than go make noise . good luck give you stuff to think about.
Nov 19, 2009 | Dodge Pickup Cars & Trucks
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
00 Jeep GranCherLim Mayday! I'm goin down!
You would have to put the Jeep up in the air on a lift. Put it in 4wd and check for noises from the front hub bearings.
Nov 19, 2008 | 1999 Jeep Grand Cherokee
Not cooling
disconnect power ...remove lower back panel ...... remove fan and replace.... used appliance shops are a good place for free or cheap fans
I have done this many times on my rental properties
ed
Oct 20, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Referral from Ekse. DLP Samsung spinning noise
the most likely cause would be either the color wheel or the cooling fan. If you listen at the rear cover can you dtermine where the noise is loudest? does the noise instantly go away when you turn the power off after its been on awhile? If so its the color wheel, If not its the cooling fan.
Sep 06, 2008 | Televison & Video
Vornado 723B Fan Logo
476 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
