Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Model #110.2262101 Serial #CL3602829
This washer fills but when it starts to agitate it shuts off and reads CL. The washer repair place has replaced the water pump, drive motor and motor control board. They are at a loss and I am out several hundred dollars so far. Isn't this probably a mechanical problem like too much resistance in the tub rotation? Thanks, Sherm My Calypso washer also had a CI error. I got a level out and tried to make sure it was level and noticed one of the back legs was missing. I found it in the pump box that was repaired almost 2 years ago. When I reinserted the footing, I leveled it. When I started the machine, I would get an OB instead of CI. Then, I would redistribute the clothes and my machine worked - for 5 loads - then would resort back to the CI error code. I called Sears and they sent out a tech who told me it would cost $535, for which I declined the fix. Looking at these boards and posts, I've taken my machine apart, down to the U-Joint. When I first lifted off the control panel, I found the left wire on 2nd or 3rd "silo" on the left side, coming off. I reattached it and continued to dismantle the machine. I've found tons of lint, some in the pump housing and throughout the washer. I've cleaned everything off and am about to reassemble it but now wonder if I need a U-Joint and seal kit. I see more lint in the outer plastic washer housing that may also contain more debris after I remove the U-Joint - which has a lot of lime/scale sign on it. Help, I've been without a washer for a month now...thanks in advance for anyone who may help me out on this one....kk
  • 15,935 Answers
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Calypso #110.2262101 SN-CL3602829 CI error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore calypso model 11022082101 Machine operates normal till a small amount of water in then fails to agitate at all. Does nothing and LED reads normal.
sounds like a lid switch is bad. If you can open the top of the washer cabinet and find the door switch should have two wires disconnect wires from door switch and hold wires togetherand wrap with electrical tape then try the washer. If it starts agitating, this will tell you if its the switch
Aug 25, 2009 | Washing Machines
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Callypso Model #gvw9959kl2 Serial #cm3202070
I had the same problem, it turned out to be the "U-Joint", which was a fairly easy repair. The part comes as a kit, (It is probably very common), the cost I got from Sears was $112. With tax and a $44 overnight delivery charge, my total was $170. And while I had it apart, I also cleaned all the gunk out.
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
