Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven working no gas to range
Oven works but no gas to range
  • 1 more comment
  • hpb321 Jun 03, 2009
    oven getting gas top of stove is not
    where is top valve at?
    thanks power went out and oven locked itself didn't they could do that
    President:
  • 1,902 Answers
Check to make sure that you are getting gas to the unit itself. If you are getting gas to the unit from the shut off valve. Then your problem would be the gas valve will need to be replaced. This is the only thing that would not let the gas flow to the unit itsef
Posted on Jun 03, 2009
  • 2 more comments
  • Jeremy Reddick
    Jeremy Reddick Jun 03, 2009
    There are two gas valves in ovens just to let you know
  • Jeremy Reddick
    I understand that. What I am saying is that all stoves have two gas valves. One for the range and one for the oven
  • Jeremy Reddick
    They are both located in the back of the unit behind the broil case. You will see two different gas valves and the one for the range is the very first gas valve and is bigger in general
  • Jeremy Reddick
    You are welcome. Thanks for staying with me and yes they can do that but that is kinda rare to happen. Take care and have a great night
No gas to the burner or oven
Hello deodatramdin - If both the range and oven are not working, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. While the unit is turn off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (typically located on the back left-hand side of the range). This valve shuts the gas off to the oven. Once you have verified, turn the range back on. If it proves to be ineffective, then the range could possibly be experiencing an issue with the EOC, wiring failure or faulty power supply. Contact a certified technician to move forward accurately and to assist with the repairs.
Jan 30, 2013 | Frigidaire FGB24S5A Gas Single Oven
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Magic Chef range
Ignitor is very fragile and may have cracked.
Nov 28, 2007 | Magic Chef 9122 Gas Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
149 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
