Question about Fuji FinePix F30 Digital Camera
Buttons Messed Up and Screw Driver Size
My F30's backside control buttons are messed up. I mean, when I hit zoom in/out, nothing happened, but when hit disp/timing/flash/flower buttons, they did a job of another. The power button, wheel and the picture buttons on the top works find, and the camera can take pictures. I thought it's a connection problem, but I can not find a right screw driver to open the case. So, here comes my second question, where could I find such a driver, and what is the proper size, #1, #0 or #00?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I had exactly this problem and was able to fix it.
Two of the screws on the case are 'special', with a Y-shaped slot. The appropriate screwdriver seems to be known as a "tri-wing" screwdriver and is sold on ebay (and elsewhere) to open the Nintendo Wii and DS amongst other things. I bought one on ebay, and it worked fine although I think one size smaller would have been better. The screwdriver is labelled 360/Y x 50.
Opening the case was easy. If in doubt there are videos on youtube showing how to replace the LCD display that show how to do it. The only place it was tight was on the side just below the shutter button.
In my case the problem appeared to be that the ribbon cable connecting the button-membrane to the main circuit board had been creased (folded too tightly on itself) although I have heard that the same problem can occur if it isn't properly seated in its socket on the main board. The buttons worked perfectly with the case open, but failed whenever the ribbon cable was squished flat by closing up the case.
I folded the edge of a small piece of paper to make a small roll, and taped it in position just behind the crease in the ribbon cable so that it prevented the crease from flattening completely even under the pressure of screwing the camera together again.
Amazed and delighted to have my camera fully functional again for the price of a cheap screwdriver and 30 minutes fiddling.
Posted on Aug 15, 2009
  • 1,305 Answers
You can get these at the local electronics store... they'll have them in sets with phillips and straight blades... great to have a set for stuff like this...
Posted on Jun 03, 2009
Problems with macro close ups
First make sure the lens is clean. Now set the dial to P mode. Hold down the flower button for a few seconds and the camera will go into "super macro" mode - keep watching the screen or the viewfinder until this happens. You might also feel the zoom resetting itself. You can now go right up to the subject, literally almost touching it - be careful not to damage the lens by hitting the subject! I think in normal macro mode 4" is too close.
May 05, 2010 | Canon PowerShot S3 IS Digital Camera
Coolpix macro problem
I called customer suppot.
Follwed these steps:
1. Make sure camera and subject are perfectly still
2. Push flower button till white flower is on screen
3. slowly press zoom in and out till flower turns yellow
4. wait 10 secondes or so
5. camera will focus on object
6. if not, press zoom in/out again, then wait again
Jul 10, 2008 | Nikon Coolpix 5700 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Camera problem canon A520
Did you accidentally hit the "Disp." button (lower left corner)?
Jan 21, 2008 | Canon PowerShot A520 Digital Camera
Repair Fuji F30 shutter button does not work, case damaged
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the most 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
NB Remember to only open the backside of the casing, there is no need to open the lens-side. Opening and closing the backside is really easy and could be done by anyone with the right tools. (read screwdrivers...)
Oct 28, 2007 | Fuji FinePix F30 Digital Camera
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Fuji FinePix F30 Digital Camera Logo
322 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
