Question about Whirlpool Duet GHW9150P Front Load Washer
Spin Cycle Washer bounces all over the place just got it today It's level but it knocked a hole in my sheet rock before I could stop it
  • 530 Answers
Take the shipping bolts out of the back. they are usually yellow in color and there are 4 of them
Posted on Jun 03, 2009
Ftf530es knocks during spin cycle
Good Morning Friend,
I understand that your Frigidaire washer, model# FTF530ES, is having trouble with the drum rocking back and forth, from front to back. I suggest making sure that your washer is level. I would check from front to back, side to side, as well as from corner to corner. If you have leveled your appliance and are still noticing the drum rocking from front to back I would suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
First time I ran the electrolux washer, it bounced around during the spin cycle and gashed a hole in my wall. We can't run it without it bouncing violently. When it is not running, all four corners are...
Sounds like it could be a few things. the tub sits on shocks attached to the bottom of the machine. If one of those are broken when it goes into high speed spin ght thing will bounce around violently. Also the tub hands on springs from the top. Its uncommon but one of those could have broken or let go. The cabinet will not move but the internal components can be destroyed by it.
Apr 04, 2010 | Electrolux EW1000i Front Load Washer
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
Rocks and bounces during spin cycles
You don't state what type and model of washer you have but following is the Whirlpool service manual for top load direct drive washers.
Check the sections on the base and suspension springs and pads.
If one or more of these is not connected, or the pads are damaged, the washer will vibrate during the spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 22, 2009 | Washing Machines
Kenmore 80 series will agitate but not spin or let water out.
Hi, I know washer had a party, he just need a dancing partner, joking, that's a common problem, when machine is not properly level, you should used spirit level, to level machine, after leveling machine, place both hands on machine, and try to rock it from left to right, forward and backward, and it should not have any play, if there's play adjust legs to compensate, water has to be pumped out first before machine spins, rhere's something wrong with water pump, maybe some fabric stuck in pump impeller, or maybe wires disconnected from water pump, remove back of machine and check connection to water pump, check for kink hoses, visual check, if wire were remove, connect to water pump, you're smart. good luck.
Aug 08, 2009 | Kenmore 24032\24036 Top Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
The washer comes to life on the spin cycle lol
IS THE WASHER LEVEL ? YOU'LL BE SURPRISED HOW MUCH THIS WILL EFFECT YOUR WASHER JUST PUT A LEVEL ON IT TO MAKE SURE IT'S PLUM
Apr 12, 2009 | Washing Machines
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
