Question about LG GCC 4320B CD-RW/DVD-ROM Burner
I have a gateway with windows xp and my dvd rom won't read dvd-r
I am trying to burn a movie.
  • LG Master
  • 13,433 Answers
It could be that your dvd drive is only able to read dvd discs not to burn them, if its a combo drive its very likely a cd burner that can read dvd discs.
if you send me the brand and model or the full name / details of the drive I could check on it.
Posted on Jun 03, 2009
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
Can't burn videos
you have to determine if this is a codec issue or a dvd rom drive issue try to burn a cd using music files if that works but does not burn movies the you need a replacement dvd rom drive.
May 12, 2010 | Gateway 505GR PC Desktop
Computer reading pioneer dvd rw burner as a cd rom not as a dvd r
Please select the recorder in drop down menu, once you select your DVD writer, you will be able to burn movies.
Sep 09, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
DVD-Rom will read the movie but won't write (burn) it. Bad block of memry
>> The Device has a bad block of memory, which Windows attempted to read.
Which CD/DVD disk are you trying to _read_ ?
Can you read this disk in a different computer ?
If not, then the disk is scratched or greasy or otherwise damaged.
Does the error occur when you try to start to _write_ ?
If so, the "blank" CD/DVD media may not be compatible with your hardware.
Find a "writable" disk from a different manufacturer, and try to write to it.
If that works, then you may need to do a "firmware-upgrade" on your CD/DVD-writer, to make it compatible with newer "blank" media disks.
Apr 25, 2009 | Computers & Internet
Cant burn a CD/DVD on the Samsung DVD-Rom SD-616Q
This unit can read most formats, but it doesn't support write operations.
Mar 26, 2009 | Microsoft Windows XP Home Edition
DVD Rom Drive Won't Play Some CDs...
Couple of possiblilities. Hardware or software.
You can go here to get the latest drivers for your system , just put in the serial.
http://support.gateway.com/support/drivers/dlcenter.asp
Or here
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&model=10651&os=&type=&st=browse
If it is listed correctly in the system , it is probably starting to fail. You can try cleaning the laser lens GENTLY with a cotton swab and alcohol.
Also you can try and flash the firmware of the drive. The format of DVDs change slightly over time sometimes making newer ones unreadable. Here is a site with flash utilitys for your drive.
http://tdb.rpc1.org/#GSA4082N
If you still have issues , you may need to replace the drive. Cheapest one I could find was $179
http://www.notebookparts.com/products/description.php?II=11272
Might be cheaper to go with an external one if you can get one cheap.
Mar 01, 2009 | Gateway MX7118 Notebook
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
Jun 21, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Wont recognize a blanck dvd rom
Try downloading the latest drivers and firmware
Feb 05, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
LG GCC 4320B CD-RW/DVD-ROM Burner Logo
113 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
