Question about Epson Stylus CX5000 InkJet Photo Printer
Can't add printers to Mac
Hi Guys
I’m not savvy, but I can follow directions, and this has me scratching my head.  I have 2 printers “Y” – connected to a single USB port (which worked OK on my PC).  After connecting to my new Mac, I updated the drivers for both and now the Mac doesn’t see them and they aren’t available in my System Preferences.  I downloaded each driver a few times and sometimes the HP will be shown in the Pref’s, but it will still say it doesn’t see it.
Mac OSX 10.5.6
Epson Photo Stylus R1800
HP Photosmart C3100
Thanks for any suggestions
  • jopatco Jun 03, 2009
    Good idea - I'll try it tomorrow.
    Thanks
  • 864 Answers
Can you install them individually (i.e. connect only one printer with a single cable to the USB port)?  If you can and then connect them both through a USB hub you may be able to see them both in the printer setup and select the one you want when printing.
Posted on Jun 03, 2009
How to install network printer
Go to "Start" on any computer on your network.
Choose "Add a network, wireless or Bluetooth printer."
Choose your Canon printer from the list of available printers.
Select "Install Driver" if prompted.
(OR)
If you have any issue while installing Call on Printer Tech Help Support Toll-Free number 1-855-887-0097.
Sep 27, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to add hp 2025 printer on mac laptop via wireless network?
Hi. There are two steps. First the printer must be connected to the wireless network - see the installation instructions that came with the printer. The mac is not involved in this part. Until you get it done you will not be able to do anything else.
Second. make sure you have the most up-to-date drivers for your printer installed on the Mac (this applies to any printer - not just your HP). Once the drivers are installed, go to System preferences and select "Print & Fax". and hen click on the + sign to add a new printer.
Wait a moment or tweo and the printer's name should pop up. Click it's name then wait for the drivers to be identified - this can take several minutes so be patient. As it's an HP you will probably get a bonjour connection but a word of warning, I have had more trpouble getting Macs and HP ptinters to work reliably over WiFi than any other make.
Apr 06, 2012 | Apple MacBook Mac Notebook
LASERJET M1005 MFP) SCANNER ERROR 12 DISPLAY IN A SCREEN I CAN NOT SOLVE THIS PROBLEM NO SCANNING , NO PHOTO COPY IN MY PRINTER PLEASE HELP ME HOW TO SOLVE THIS
Scan head mechanism failed. Remove flat bed glass, take out scan head unit, verify any breakage in mechanism gear pinion,if found replace gear mechanism, if no breakage found replace scan head driving motor. You can see the scan head mechanism as snap shot..followed by how to alter the pinion..
For tech guys:How to alter the pinion.
1_4_2012_7_55_18_pm.jpg1_4_2012_7_55_47_pm.jpg1_4_2012_7_56_11_pm.jpg1_4_2012_7_56_49_pm.jpg1_4_2012_7_57_28_pm.jpgFollow the snapshots, be patience & do it. This is available part if anything goes wrong don't worry.. Best of luck....
Jan 04, 2012 | HP LaserJet M1005 Printer
Hp Laser Jet M1005 Scanner Error 12.. pls tell me ho i solve it.
Scan head(A part in flat bed scanner unit moving forward & reverse while scanning/copying) driving mechanism broken, replace it.For tech guys only:> open flat bed glass, pick out scan head unit,remove screws & detach drive mechanism,, Follow the snap shots to make alteration...Pl dont try it if you are not having that much technical skills..
12_16_2011_7_52_57_am.jpgThis information is giving you to on basis of my knowledge & experience, if you find any difficulty to alter the part just replace it with new one..Thanks for using FIXYA
Dec 16, 2011 | Office Equipment & Supplies
My printer says "missing component
Please carefully follow steps below to fix this problem:
  1. If the computer is NEW and already has 10.7, download the Webdriver directly at http://bit.ly/onkHQ5.
  2. If the computer got 10.7 via the Software Updates, then run the Cleanup tool, please refer to this article on the Lexmark website: Removing Lexmark Files on your Mac 10.7 Computer
  3. Run the installer, and after add the printer via Print and Fax. Follow the steps in Solution B in this article: How to Manually Add a USB Print Queue, Network Print Queue and Fax Queue on Mac OS X Systems.
  4. Run the Apple Software Update and get the Lexmark 2.5 Drivers installed.
  5. If the printer cannot be added, run the Repair Disk Permissions, then Reboot.
If this doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X6675 Pro Colour Wireless...
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
Pixma i9900 orange light flashes 5 times
hi guys,
Flash in orange 5 times indicates that the printhead is faulty so that the printer cannot detect the printhead. Rarely, faulty logic board and carriage unit may cause the same problem.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon i9900 InkJet Photo Printer
Trying to print to a Toshiba copier (e-studio 207) from a Mac
try to print (apple key and P together) this will cause the print window to appear. The top line is printers click on the blue button and you will get a list and an option to add a printer, click add and follow instructions!
Nov 13, 2008 | Toshiba e-Studio 350 Copier
Verizon Westell 327w - can't get all devices going
You need to select the Reset option on the interface, so it reassign news IPs to all the 8 devices. Hope that will helps!
Jul 02, 2008 | Westell Wirespeed VersaLink...
Epson Stylus  CX5000 InkJet Photo Printer Logo
650 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
