Question about Casio Exilim Zoom EX-Z80 Digital Camera
The camera says card is locked but the card itself is not.
Will let you view the pictures but will not let you erase or take any more.
    President:
  • 272 Answers
There is a little sliding switch on the edge of your card. If it is up your card is 'protected' and in read only mode. Slide it the otherway and it should solve the issue. It's very, very small right on the edge of the card...Very easy to move during install and removal of card.
Posted on Jun 03, 2009
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Pictures Lost???
Get an inexpensive card reader and try to download the pics to a folder you create on your desktop.
Nov 30, 2009 | Olympus SP-500 UZ Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick.And there is nothing in the manual about how to fix it. When I turn on my camera I get an error...
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
Apr 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon SD1000 keeps erasing pictures
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
Finally AFTER you've recovered your photos, consider formatting your card IN YOUR CAMERA (did you do this when you first got the card? if not, this is what eventually happens). Keep in mind formatting the card will also totally and permanently erase the card. Press menu, then select the tools menu, then scroll down to the selection stating your cards memory capacity and select it. Then follow the on-screen prompts for a "low-level" format. This should help prevent this from happening again in the future.
Jan 19, 2009 | Canon PowerShot SD1000 Digital Camera
Card Lock, when the card is not locked.
Solution,
Wrap the Camera with the purchese receipt, and bring it to the store you bought it from. They will send it back to Canon to be fixed. Hopefully it happened within a year from the purchesing date, so you will be fully covered by the manufacure warranty.
Good luck.
Dec 03, 2008 | Canon PowerShot A75 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Memory Card Error
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Try removing the card from the camera and be sure that the switch is not in the locked position.
Jan 01, 2008 | Canon PowerShot A450 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Casio Exilim Zoom EX-Z80 Digital Camera Logo
106 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
