Question about Frigidaire FER211A Electric Dryer
Frigidaire FER211AS2 dryer drum belt
My dryer drum belt broke i need help in how to install it. How do you get to the area where belt goes? Drum turns but makes noise
  • 24 Answers
The washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
2 Suggested Answers
juststinks
  • 98 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
you will have to take it apart to get the drum out. you have to take the top off
Posted on May 06, 2009
Haier dryer makes grinding noise and drum not turning. Drum turns by hand but not when turned on.
belt probably broke and tangled around motor --will need to open rear panel to see if belt broken or popped pulley
Jun 15, 2016 | Haier Dryers
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Oct 05, 2014 | Dryers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
Fridgaire dryer model #FDEC216RES1 drum isnt turning
If the dryer does not turn then you need to take the back off and see if the belt has broke or come off. If the belt broke or came off then you can get a new one at most home repair stores. If the belt is on and or not broke the see if the wheel mounted to the motor will freely spin. If it does spin the make sure that the electric wires attached to the motor itself are attached and there are no shortages from the motor to the relay on the back of the control panel.
Jul 03, 2012 | Frigidaire Electric Dryer
What's your problem?need to change belt on a fer211as2 how do i get to it
UNPLUG DRIER, REMOVE BACK PANEL.THERE MAY BE A NOTHER
PANEL TO REMOVE TO GET TO THE MOTOR AND DRUM. STRECH
NEW BELT OVER DRUM AND ON MOTOR.
Sep 30, 2011 | Dryers
I just had the belt replaced on my "Maytag" Gas Clothes Dryer Model #DG608. The repair man installed the new belt with the smooth side toward the drum as per one set of instructions derived from...
Herman usualy the groove side goes toward the drum which means it rides on the pulley from the motor disconnect and lean backwards to get a visual
Apr 05, 2011 | Dryers
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
Frigidaire FER211A Electric Dryer Logo
504 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
