Question about iLO DVDRH04 DVD Recorder
The tray will not open and cover on front came off
The tray quit opening and then the cover on the front of the tray came off. Can I order another one as I've lost it. The tray makes noise like it is trying to open but does not. Everything on the hard drive works fine.
If I can't fix it is there somewhere the unit can be mailed to be repaired? If so, what is an estimate of general charges?
Thanks
  • 3,267 Answers
Try to locate an authorized dealer closest to you & if still under warranty it should get replaced free of cost, except for the cover. If not under warranty now look up in the net for the nearest Authorized service center and contact them via telephone first and foloow their advice. The tray & the cd/dvd drive may require to be replaced..............sodeep
Posted on Jun 03, 2009
Ditections on how to install new batterys on pride jazzy 600 power wheelchair
Open the rear cover. Disconnect the large power plug.
Remove the retainer pin from the front footplate assembly.
Lift the footplate and front panel assembly up and then forward.
Slide the battery tray forward - minding that the battery power plug will need to travel to the front.
Once the tray is out, unsnap, unbolt and replace the batteries.
Reassemble in reverse order.
Nov 07, 2013 | Health & Beauty
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Where is waste toner bottle in ricoh aficio mp c5000?
waste toner bottle is just beside paper tray 1. its the left side small cover. open the front cover and open the screw from top and open the cover in front and pull the bottle out. if its hard then email me on ronils_singh@yahoo.com.au. i am a Ricoh tech. i will help you out.
Sep 27, 2010 | Office Equipment & Supplies
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Tray won't stay open
My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it.
Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
Jul 09, 2009 | Pioneer XV-HTD520 Multi-disc DVD Player
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Output tray problem
The problem may be the lever that presses on the spring is not making contact when the output tray is open. But when you press on the tray it moves just enough to make enough contact so it operates. That contactor is just visible through the little opening. It may be possible to bend it carefully, ever so slightly until it works the way it supposed to. Also shine a bright light into the opening and see if the plastic part of the tray is not broken. I don't think that it should affect CD printing (if you jumped the switch) because the tray needs to be open to access the CD tray. So if the microswitch does not contact the tray nothing will work. Remember the doctor should look down the patients throat before he removes the tonsils
Feb 21, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
iLO DVDRH04 DVD Recorder Logo
88 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
