Question about Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier
Noisy/buzz i have a crate spa1400 power amplifier that seems to work fine but has a buzz/noise in it.
  • Rommel Cana
    Rommel Cana May 11, 2010
    when engine is running?
  • 87 Answers
Usally a ground loop isolator will fix that problem. It plugs into the RCA's between the radio and the amp.
Try to reground the amp in a different spot.
Or run a refrence ground from the deck to the amp next to the remote turn on wire. (still keep your main amp ground hooked up)
DO NOT run your power wire next to the RCA's, that will induce a field which in turn can cause that buzzing sound.
Posted on Jun 03, 2009
Peavey Ecort is working fine but has a loud buzzing that slowly gets
This is often caused by the failure of the large capacitor(s) in the power supply. The noise being the 50/60hz mains hum getting in. They will be the biggest Capacitors in the system with a value around 4700UF or greater, so you can't fail to see them.
Jun 14, 2013 | Peavey Audio Players & Recorders
Noisy
The noise could be from dust that gets in cpu fan or power supply fan. Clean them but do not open the power supply. Better replace your power supply.
http://pcsupport.about.com/od/nonworkingcomponent/ht/fannoisetb.htm
Mar 14, 2012 | Codegen PS-400W-12 (PS400W12) 400-Watt...
Hello im sorry but not speak english a litle, im need picture of power amplifier crate model spa-1200 made in u.s.a.fabricated for slm electronics,1400 ferguson ave. st louis mo. 63133 and not found...
Hi,here is the one upper version of it as "Crate SPA1400 model " 1400 watt Stereo Power Amp.they are identical ..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Crate SPA1400 Stereo Power Amphttp://cgi.ebay.com/Crate-SPA1400-Stereo-Power-Amp-/270771488929?pt=LH_DefaultDomain_0&hash=item3f0b3d08a1
Jun 25, 2011 | Audio Players & Recorders
My powered mixer Behringer is buzzing
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Jun 02, 2010 | Behringer POWERED MIXER, 20 CH, 400 WTS...
I have the all tube Crate TV-120. When I turn it on it fires up fine. When I switch the standby on I get a loud whistle sound and can hear a humming from the speakers. I can also get a low guitar volume...
This is a guess: I suspect the bypass switch on that effects loop jack is causing a problem. These jacks cause a lot of problems. The switch passes the signal through if there is no plug for an effects in the jack.
You can SOMETIMES tighten up the contact to restore the jack. You have to disassemble teh unit to get at it of course.
Jan 23, 2010 | Crate SPA1600 Power Amplifier - SPA Series...
Intermittent shorts in a Crate Limo TX50DE Guitar
turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
yostamplifier.com
Feb 20, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Crate spa 400
you might need to see what your volts are if there 14.4 at the amp thats good but see what they drop to ....
Jan 01, 2008 | Crate SPA1600 Power Amplifier - SPA Series...
Open Questions:
Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier Logo
263 people viewed this question
Top Crate Car Audio & Video Experts
xxxxxx xxx
Are you a Crate Car Audio and Video Expert? Answer questions, earn points and help others
