Question about Philips HTS3450 System
Dvd player works, but no sound from any speakers
I have had this thing for less than a year and it worked great up until about a month ago, now the dvd player still shows the picture, but there is no sound coming from any of the speakers including the sub. i called phillips and they will not fix it under warranty because i lost my receipt. i dont know of any ways to fix it or what i should do. i have checked and rechecked all connections. any help would be very helpful
  • 9 more comments
  • jenny_jane Nov 01, 2007
    I have the same issue with mine! It stopped working this morning in fact, and I too have had it for less than a year. Picture works, DVD picture works, but there's no power going to the subwoofer, so none of the speakers work. We bought an extended warranty and I hope we kept the receipt...
  • Anonymous Nov 03, 2007
    same here with mine just static sucks will never buy anything made by philips again
  • jbrandon Feb 19, 2008
    I too have the same described problem with the Philips HTS3450. I've had it for about 15 months now and the speakers just quit working. The main unit and sub-woofer cabinet where all the amplifiers are located are both getting power, but no sound. My guess is a power supply problem. Any fixes for this would be appreciated.
  • klester Feb 23, 2008
    Exactly the same problem here. I suspect a power supply problem as well, but hoping to find a DYI fix. Anybody?
  • CHARJ Feb 29, 2008
  • Anonymous Mar 19, 2008
    Mine would make sqeaking, squelching, or static noises for the first 10 seconds after being started. After that there'd be no sound so I'd have to press Mute twice to get the sound.
    My problems started about a week after the warranty was up, and it was about a month before I got sick of it and called Philips.
    They were great. They apologized for the problem and said I'd have to drive it to their nearest dealer, about 25 minutes away, but they'd replace it, even though I was out of the one year warranty.
  • Ehoffa Apr 27, 2008
    I have the same problem, no sound while playing DVDs. My sound slowly started offering static scratching sound and progressivly got worse with time. Now, I no longer have any sound. I am looking for a repair. Please send me a response to
  • landonblaine May 25, 2008
    I'm having the same problem. Gradual hissing when powering up over the past couple of months, now there is no sound at all.
    A solution would be great. Thanks in advance.
  • JillF Jun 16, 2008
    SAME PROBLEM! I called Philips today to report this and they do not have a replacement subwoofer at this time. It would also be at my cost to replace it since it is over the year warranty. Isn't that convenient? Ours is getting tossed and we will look at a new system.
  • roxy6 Apr 16, 2009
    can't find those caps in the sub woofer they are not the same numbers on the caps in the sub they are 1000 uF/ 50 v And its also hts3450 confused
  • wajeh_mak May 11, 2010
    what should i do with my problem that i have no sound on my dvd player ?
  • 20 Answers
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Posted on Jul 26, 2008
I had the same problem except my volume would just decrease after a few minutes of being on like someone was pressing the volume down buttton. If I walked over to the subwoofer and gave it a knock on the top the volume would instantly come back on where I had it set before. I took WheatService's advice and replaced the 470uF/25Vcapacitors and everything is working great now. I am very pleased. BTW, the parts at radio shack were like $3.00. I needed a desoldering tool, which I would recommend for this job...the one with the suction ball. I also needed some more soldering wire for a total repair cost of about $17. If you have all the tools the capacitors will cost you $3.00. Philips wanted to send me a replacement unit for $100.00 and I'm sure the local repair shop would have been the same if not more. Thanks again, WheatService!
Posted on Aug 12, 2008
Follow WheatService's instructions for repair. I repaired my unit having the same symptoms as other posts here and it works like a charm... for under 5$!!! I will never buy another Phillips unit again, but thanks to the helpful information here, I won't have to run out and buy another system for a while.
Posted on Jul 27, 2008
Same problem here. I've had it for less than a year too. I was unplugging the jack that goes from the sub to the dvd player multiple times until I heard sound and that worked for about a month, but now there is no sound and shows no sign of ever producing sound again. system sucks...
Posted on Mar 05, 2008
Well for Phillips guy HTS3450.
I have the same problem and i know how to fix my problem.
If u want to know email me and ill tell u. jerome_biggie at yah00
but again my problem was easy to fix honestly i didn even do anything.
If any of u guys wat to know ask me personally and ill tell u.
But again my system is HTS3450 and maybe it wont work for u.
Posted on Mar 03, 2008
  • 4 Answers
Buy a new unit !  phillips is notorius for power supply failure and sound output well as plasma failures as well as.... you get the phillips drift        and their warranty  department *@#@*^sucks   hope i could help                imanfix
Posted on Oct 24, 2007
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
I received my Philips DVD5140 player years ago as a present. A few months later, my player began to act up. It now takes a long time in the loading process until finally after a while responds with...
You need to look at the lens of the DVD player. With it switched off of course! If the lens has a scratch on it the player will not read the disc.
May 22, 2017 | Philips MX5100VR System
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
yes, company will charge you, but the best suggestion is to get repaired from the company person.
The normal problems are bad contact of speaker wires and settings of sound from the sound menu. I think you are a genius guy, so you might have checked such things, so now its better to give it to PHILIPS SERVICE CENTRE.
Apr 23, 2009 | Philips HTS3450 System
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
Front speakers have no sound now.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
May 05, 2008 | Yamaha HTR-5830 Receiver
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
Philips HTS3450 System Logo
647 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
