Question about Husqvarna Garden
Brand new husqvarna 445, won't start
From post by someone else: Did everything exactly as directed, tried a few times, including leaving alone for a while, nothing. I have the same problem with my brand new 445: followed all directions, but it won't start. And yes, I do smell gas after trying to start. Also, some smoke is generated after several pulls, but it won't turn over.
  • 1,041 Answers
Try not giving any throttle when first starting. The newer trimmers are this way many times. (Maybe the newer chainsaws are this way now.)You prime the carburetor, set the choke and pull, but don't throttle until it runs for 10 or 15 seconds.
Jim
Posted on Jun 03, 2009
  • Jim Parker
    Jim Parker Jun 07, 2009
    Any luck getting it started?
    Jim
Husqvarna 445, starts runs and dies. as if it was a fuel problem.
You seem to have changed everything, are you sure this is not an ignition unit issue? i have to confess the unit is not the best quality, i think the next move is to replace it.
Mar 15, 2018 | Husqvarna 445 18" 45.7cc Gas Powered Chain...
My 445 fills the cyl with fuel every time I try to start it I had change the priming bulb
The problem probably lies inside the carburetor. The needle valve is either dirty or worn, or the float has a pin hole and wont float or perhaps a misalignment on one of the visible components. The valve that opens and shuts the fuel flow (needle Valve) is generally the culprit. This is due to leaving fuel inside the carburetor over Winter. The fuel evaporates and leaves a very sticky varnish that messes everything along the fuel lines. This Winter...empty it!
Oct 23, 2014 | Husqvarna Garden
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Hu700f won't start
My huskuvarn will not start put a new carburetor and a magnitude coil on it it is brand new and will not start it is a 700f husqvarna any suggestions on it plus like I said a new coil and it is not sparking and not starting please help me out
Feb 18, 2013 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
My Husqvarna starts but won't accelerate when you pull the trigger, acts like the brake is on but the handle is in the free position.
It may be running very rich, make sure the air filter is clean, if ok. check the spark arrestor in the muffler outlet ( if fitted ) has not carboned up, if ok, check the exhaust port is not blocked with carbon.
Dec 30, 2012 | Husqvarna 445 18" 45.7 Cc Chainsaw...
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Hi
there is too much gas accumulated at the plug.Remove the the plug ,turn the switch at off position and opperate the starter for few times until the cilinder has no gas inside.Try to start the engine.
regards savumihai71
Mar 15, 2009 | Husqvarna Garden
Garden Logo
783 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
