Question about AudioBahn A8001DT Car Audio Amplifier
My amp plys in burst
I have a audio bahn a8001d amp and my led reading works but my sound plays for a second then it stops for a second, so it plays in burst constantly. what do you suggest the problem is and how can it be fixed?
    Novelist:
    Champion:
  • 219 Answers
Make sure you have the correct speaker load.  Try one channel and one speaker (4 ohm single voice coil) at a time and see if there is one channel that is the problem.  See if it will stay on with no speakers attached.
Posted on Oct 24, 2007
SOURCE:
Not working proper
Internal issue have seen it with all of this brand amp, was not able to repair, sent in to the manufacture and they sent it back, still had same problem, recommend a different brand, kicker, rockford fosgate, pioneer, alpine, kenwood, audio bahn, I've installed some dual amps and they seem to work quite nicely
Jun 03, 2010 | Boss REV-3000D Car Audio Amplifier
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
How can i get this amp out of protection mode?
You have a short circuit. I don`t know this particular piece of equipment but you should check all the output transistors/chips. Try disconnecting ALL the supplies to ALL the output devices and switch on, It should fire up, If it does, reconnect the positive AND negative supplies to one channel. If it still fires up, reconnect the next channel until you find the faulty channel then you could try doing comparison checks between the bad channel one of the good ones. These amps tend to use MOSFETS and are extremely intolerant to bad or loose connections. I hope this helps. You`ll probably find that you`ve got poor wiring, That will be your original fault. Ensure you make ALL connections good and sound before reconnecting the amp up with new devices in or you WILL be back at square one with no amp again. Ian
Jul 19, 2009 | AudioBahn A8001DT Car Audio Amplifier
When playing a DVD, picture & audio stop for a second one a while, no problem when playing a CD
this may just be the mechanism changing diretion as it reads the second layer on the disc usually because the film is too long to go on one side of the dvd disc.
quite normal.
but if happening quite a lot during playing a film then it could be something as simple as cleaning the mechanism. NOT for the untrained
Jun 01, 2009 | Teac DV-H550 DVD Player
Audio bahn a 1800
If it has cooled down and still goes into protect mode, it likely has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 23, 2008 | AudioBahn A8001DT Car Audio Amplifier
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Audio not working on new custom PC
in the control panel check sound and audio devices option- audio-default playback device- default recording device. Check whether sigma tel audio is present by default. if not then try changing to dafault audio devices both play back and recording options.Restart computer to check sound is heard this time.. all the best !
Dec 20, 2007 | Intel Motherboard
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
AudioBahn A8001DT Car Audio Amplifier Logo
55 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
