Question about SanDisk Sansa e260 MP3 Player
Help me How do switch to recovery mode..
    President:
  • SanDisk Expert
  • 650 Answers
Download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Posted on Jun 03, 2009
Load main image failed switch to recovery mode
but how do i switch it to recovery mode?help me please..thanks
Sep 19, 2011 | SanDisk Sansa e250 MP3 Player
How to switch to recovery mode
Download the Sansa Recovery Tool from Sandisk's website to enter recovery mode.
The link to the manual is here:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260
1)Shut down the player.
2) Make sure the hold switch is engaged.
3) Hold down Reset and Menu buttons until system starts up in recovery mode.
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
My mp3 player wont work it's at the refresh datebase screen.
hi what you need to do is goto sandisk website and download the latest firmware but before you do that try and put the mp3 into recovery mode if it goes into recovery mode then you can install the latest firmware this is how to put it in recovery mode
1. unit off slide lock switch to lock position
2. hold down rec button on left hand side
3. whilst holding rec button switch mp3 on whilst still holding rec button
this should now be in recovery mode now download firmware and follow instructions this should solve your problem as long as it is a software problem let me know how you get on ok
Feb 25, 2008 | SanDisk Sansa e250 MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Recovery Mode
Recovery Mode doesnt help if you dont load anything.
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Load main failed switch to recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e260 MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
144 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
