Question about Water Heaters
New Noritz 751M-OD not getting up to temp. - Water Heaters
    Scholar:
  • 73 Answers
If you mean the water at your fixtures isn't getting hot, then you should initially check for a cross connection. A cross connection is cold water leaking into the hot water system. The easiest way to check for one, is to shutoff the cold water entering your tankless heater and then open up hot water fixtures throughout your home. The water at your fixtures should come to a complete stop (it may drain for a while, especially if you have a 2 story home). If you see a continuous stream of water, then you have a cross connection. The most common place for a cross connection to form is at failed shower cartridges.
The next most common reason for improper output temperature would be insufficient gas supply; however, this would be accompanied by combustion error codes such 90, 59, 11, and 12 codes.
Posted on Aug 14, 2009
  • 332 Answers
Check the thermostat this would be the only thing keeping it from getting to any temp,, other then the gas valve, is it constant or happens here and there;;;
Posted on Jun 11, 2009
Can we change the orfice on our Noritz N-0751M natural gas to liguid propane?
There's a field conversion kit available. Contact Noritz to get more information.
Mar 30, 2011 | Noritz Residential Heaters Tankless Water...
I'm working on a n-0931m noritz and i have a 61 code flash and water leak out the blower housing i assume the heat exchanger is bad. is a heat exchanger difficult to replace
61 code is a fan motor abnormality. It typically indicates the fan is damaged and needs to be replaced. It can be caused by water leaking onto it from the heat exchanger.
The heat exchanger isn't difficult to replace, but it is confusing if it's your first time doing it. I'd recommend calling Noritz for assitance.
Mar 12, 2011 | Noritz Residential Heaters Tankless Water...
How do I manually change the temperature on Noritz N-0631S tankless water heater if I don't have the optional remote controler?
There are temperature jumper clips located on the inside left wall of the heater. They will be in a small plastic baggie. The procedure is as follows:
1. disconnect power
2. install the jumper connector in the plastic slot located between the remote control screws on the circuit board (right hand side of the heater)
3. reconnect power
Mar 06, 2011 | Noritz Residential Heaters Tankless Water...
After freezing weather the Noritz N-0751M-OD started leeking water and now there is no power to the unit or panel..is the unit toast?
I believe you killed it,I've installed two units direct vented through side wall in Minnesota and the cold wind blew in flu and froze up units,water stopped running in houses so we were able to save
Jan 28, 2011 | Noritz NORTIZ Outdoor Propane Tankless...
Would you recommend this brand or another, with your experiences. We can get a used one noritz n-069m-od for $250...Go for it or not? We live on a well, 40-70 PSI, so maybe a bit low to work well?
The thing is with these that if they have been used in a "Hard Water" area, they get clogged up inside with deposits, so as long as it's a real "New" looking, inside and out, well I guess $225 - $250 would be an acceptable price. Find out WHY it is being sold.
Apr 17, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Water heather does not com on when water is truned on wide open
when to local dist. got owners manuel which after installing 4 of these uints the person impersonating a plumber took with him. easy to understand tbl shooting. resolved tbl. thanks
Jan 05, 2010 | Noritz Commerical Tankless Water Heater...
Won't Turn on.
did you check your circuit breaker for the outlet you are pluged into, is it electric or gas, for the combustion? if it is electric you might have burned up the element it has to have water on it before turning it on, if it's gas you might just have to unplug it wait 30 seconds plug it in set the temp and turn it on
May 29, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Heater Won't Fire up
I had the same problem with my Noritz 751M, I called the plumber and after he talked with Noritz and ran a bunch of tests (for $150) he told me I needed a new unit ($4,000 installed). They implied it was my fault cause I never flushed it over 8 years. They were unable to tell me the flow rate though (which should be very low if scale was my main issue). I decided to take over as I am very handy and an engineer. Here is what I found:
1. The unit is 8 years old and was never descaled (orig installer did not install the bypass valves nor tell me to flush annually). So, I installed the valves ($70) and bought a pump/hoses/bucket/Zep CLR ($150) and did the flush. There was tons of flow thru the exchanger (I did not measure how much).
2. I called Noritz myself (they were very helpful) and cleaned up the igniter rod with sandpaper (it was very discolored due to 8 years of sparking). This did the trick and my unit fired up but it was very sporadic (sometimes yes & no). The difficult part is that while the igniter is installed you CANNOT actually see (nor definitively hear) the sparking. It seems like sometimes the spark happens (unit fires right up) and sometimes it doesn't (unit cycles and ends in a Code 11 after a couple of minutes).
3. INFO: Per the field manual (Search google for: docslide.us_noritz-field-manual-2009) you can read the flow rate data from Data #14 on the remote control. It needs to be >0.5 GPM for the sparking to happen which then triggers the gas flow. You can live monitor Data #14 by following the instructions in the field manual on pp.46-47. The startup logic is: Flow > 0.5 GPM then Sparking Happens then the Gas Flows then Flames start in the combustion chamber
4. I got mine to successfully start by loosening the ignitor rod PN 101 and jiggling it while still inserted into the combustion chamber (holding it with insulated pliers while still against the case) - somewhat dangerous and startling when after sparking the gas flows and flaming starts but not too bad.
5. BOTTOMLINE: I got it working but it would not "always" light (even though my flow was always >0.5 GPM). Noritz told me that it is probably because I have the older black ignitor (PN 126 = EHEJ003). They have a new and improved gray ignitor (PN 126 = EMUJ004). I ordered it with a couple of other ignitor parts for a total of $35. I just installed them and they work great - ignition all the time from every faucet.
6. ENDGAME: Order the new ignitor parts, verify your flow rates using the field manual. See the pics below for some insight. I spent 20 hrs troubleshooting and wanted o share. If you want more info just email me at: tmorganjets@gmail.com
You can monitor the flow rate and flame by doing a skype (PC at faucet to Phone place in front of Noritz) - you will be able to see the Noritz turning on (with flow rate displayed) each time you turn on a faucet - it is very helpful for troubleshooting and verification
Feb 15, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz not staying hot
How many faucets do you have on when this happens? Turn on more than 1 and if it still does the samt thing than I would check to see if the inlet water screen has debris in it. Valve off the unit and look at the inlet water side and theres a screeen that you should be able to remove and clean undeneith some running water and then replace. Good Luck
Jan 07, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water Heaters Logo
176 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
