Question about Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HLN5065 intermittent shut off and color scrambled display
This problem started 4 days ago when the displayed image scrambled the colors on all channels.  My wife unplugged the unit until I returned.  I powered it up and it came on for about 2 minutes, then scrambled.  I unplugged as couldn't power off normally.  Plugged back in after a minute or so.  Picture came up ~30 secs later and stayed on for a minute then the TV shut itself off.  30 seconds later it seemed to try and turn itself back on but failed.  This cycled for a few minutes so I unplugged as again couldn't power off normally or via the side power button.  I plugged in and the preceeding repeated.  I did this a few times and finally the TV came on and worked normally.  Next day this basically repeated.  I'm on Comcast cable and running DVI if that matters.  I tried antenna input and same problem.  Much appreciate any help.  Thanks in advance!
  • 1 more comment
  • guideboat Feb 04, 2008
    Mine just goes to basic black with a few white spots like a scrambled signal but we do have perfect sound. I have unplugged and let the set idle for 1/2 hour or so and had the image come back for an hour +/-, I have also had the same would not let you turn it off. Help? Thanks
  • pspc271 Apr 28, 2008
    I have the same problem. The TV will be working fine then the picture will suddenly freeze in black and white pixels for a split second then disappear all together. After shutting it off for a couple of minutes it will work fine again for anywhere between 30 seconds and an hour. I noticed one suggestion said the problem was a bad light engine assembly. Are there any other suggestions on how to fix that?
  • El Papa Jul 12, 2008
    I've had my samsung collecting dust for over 2 years because i got tired of trying to fix this same problem. I paid to get the color wheel and lamp changed but after a long week of normal service and somewhat loud noice the TV whent bad agin. The great image turned like a color negative and have not bother with it again. Is there any econimical hope for this baby or sould I just trash it.
    El Papa
Can we go further into light engine?. . .Is is shabby connectors, heat sinks, cold solder, caps, has anyone actually repaired the light engine? This is obviously a very common problem. . .I've replaced the lamp, balast, color wheel and bypassed the switch. . .mine still does this for 5-10 minutes, then will work fine forever as long as you leave it on. . .
Posted on Jun 28, 2008
    Genius:
  • 1,694 Answers
Bad light engine assembly.......
Posted on Oct 24, 2007
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Replacin the color wheel in HLN5065
U machanically incline?Not hire a tv tech. to this,because,u have to take out many machanical parts,before even can take out the Colors wheel to replaced.Try website like You Tube Type in Samsung colors wheel replacing.U will get a tutoring by some one doing or trying to replaced the colors wheel.
Jul 12, 2010 | Samsung HLN5065W 50" Rear Projection...
NEED SCHEMATIC FOR SAMSUNG DLP HLN5065
What is wrong with your TV ? Call Encompass they might have what you are looking for! 1-800-638-3328 they will have parts for Samsung. I myself own the same TV 5065W just replaced Lamp and Color Wheel.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
Display problem with my Samsung HLP5085W DLP TV
What you are describing sounds like a tuner issue. Samsung had a run of bad tuners, and was recalled. If your watching a chennel and the image tears, this is the sign of the bad tuner. It is possible that the wobulation circuit is unstable. First units we bothered by subwoofers thumping the TV. Not much help other than that, good luck
Jul 07, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
SAMSUNG HD DLP HLN5065 50" TV
The problem of your DLP TV is a defected color wheel,replaced that so it will works normal again.
Hope it may help you;
Regards,
VOTIT
Sep 22, 2008 | Samsung DLP HL-P5663W 56" TV
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLN467W 46" Rear Projection HDTV Logo
614 people viewed this question
Jerry Greenberg
Jerry Greenberg
