Question about RTO 6230 BANDSAW MILWAUKEE BAND SAW
No power (breaker, power chords, outlet are all ok)
My bandsaw will not turn on, (breaker, chords, outlet are all fine)
  • 10,865 Answers
If you have power to it and it will not turn on at all your switch needs to be replaced. You could try cleaning it first and giving it a squirt of electronic contact spray.
Posted on Jun 03, 2009
I purchased a new large Kenmore room AC unit that is reversible for heat. it was running fine all summer, but when i switched it to Heat mode yesterday, it began to put out good heat but after about ten...
It should be on a separate outlet because that one outlet your using most likely is in series which means it shares power with other sources like lights and other outlets.Maybe try an outlet in a different room using a heavy extension chord 3 prong grounded. You might want to read the circuit breaker labels and see what area is not being used much.
Dec 02, 2017 | Kenmore Heating & Cooling
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
Keeps rebooting
Hi, Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
- If it is working then fine....If not then remove all the cartridges...disconnect the power chord from back of the printer and then from wall outlet......wait for 40 seconds then connect the power chord to wall outlet first and then to the back of the printer....
- If working fine then ok or else check adapter is warming or not......and check with different wall outlet and with different power supply....
- Now do the following re-sets :
A) Disconnect the power chord from the back of the printer
B) Press and hold # and 6
C) While holding these keys connect the power chord to the back of the printer and when you see that printer is warming up then release the keys.....
Or else replace the printer.
And also some of the electrical components used to build the logic board in the Cxxxx all in one printers about 2-3 years ago is failing. In my C6180 (with the same problem), there were 4 capacitors (see green cylinder shaped component in the attached - the bulge in the top indicates failure, and that this is the likely the cause) that I replaced (cost was about 60 cents!). If you are not comfortable doing some soldering yourself, you will have to find some help - it took me about 25 min to do the repair myself. Printer works great now.
Hope it helps..
Thanks for using fixya....
Oct 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C6180 All-In-One keeps restarting and won't power on. It cannot even be used as a photo copier nor does it allow for the computer to do anything to it as it has not been powered...
- Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
Aug 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
My dryer won't turn on. it's plugged in. power is fine in the room. one of the link trap screws came out but I put it back in. still won't turn on. i can't find a model name or number printed on the...
I know you said you have power in the room, but make sure the breaker to the power outlet for the dryer has power, because most dryers are 220 volt and room power is 120 volt.
If the belt is broken on the dryer, it would also not allow the drum to turn, but the motor may be running.
Check to see if the motor is running. When motors are running with a broken belt they can almost be silent while running.
If your breaker is ok and power is ok at the power outlet, then your problem could be a faulty motor, broken belt, faulty start switch or faulty timer switch.
I hope this helps
Oct 03, 2009 | Kenmore Dryers
It won't turn on
Make sure the power chord is connected properly. Its a common problem with projection TV that the connector gets loosened. Also try a different wall outlet and make sure that Voltage is OK as projection TV requires adequate power.
Thanks
Oct 16, 2008 | Televison & Video
Basic elec oven indicator light tripped electrics??
Should be safe to use, but it sounds as if a number of things are going on. First the breaker tripping is a sign that too much of a strain on power is happening. If all oven elements are on and the oven at say 450 is tripping the breaker, make sure that grease has not gotten into the elements, and that they are in good shape. The breaker or chord or outlet may be going bad. You need to visually inspect all
Jul 21, 2008 | Ovens
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Aug 16, 2007 | Toshiba 20HL85 20 in. LCD Television
RTO 6230 BANDSAW MILWAUKEE BAND SAW Logo
161 people viewed this question
Top RTO Saws Experts
Putter71
Level 1 Expert
Jim Parker
Jim Parker
john h
Are you a RTO Saw Expert? Answer questions, earn points and help others
